Some boards have the pads for DIL ICs way too small.
This gives a saving in copper,& maybe room for thin tracks between pads.
They wave solder OK,but are nasty when you have to desolder them.
I have found that the boards I have problems with are usually European ones,Japanese ones are usually OK.
The Sony boards I used to work on were untidy looking,but worked for years,& when you did have to fix them, desoldering components was a simple matter.
The Barco boards,on the other hand,looked beautiful,but were unreliable,& you could easily cook one or two undersized pads if you were
unlucky.
VK6ZGO
