hi,
that's no arguing here, hotair is the way to go, just learn the technique and the gotcha's.
desoldering with braid, hammer or other medieval methods it's a joke
what do you do if a bga chip arrives on you bench, stretch the braid underneath?
one of my old bosses from a french R&D company that r&q-eed and prototyped + manufactured electronic modules desoldered with braid and 1kg soldering material wasted per chip, when he hit BGA he came to me and said "ok, pierre, let's do it your way" (hotair desoldering, of course). later, you will add heating plate for tough works
so, learn the good way, no some gizmos that will make you finally a bad image as a pro (even a beginner will eventually became a pro, right? that's the idea, to progress, not to find cheezy methods)
regards, pierre
