This is a lovely time saving tool if you do a lot of through hole repair. It is light weight, easy to maintain and works extremely well. To be honest, I much prefer this tool to any desoldering station both from a design and utility perspective.
Advantages:
- vacuum source is closer to the tip giving a shorter more effective suction path...no silly hose to
drag about.
- waaaaay quieter operation...it is only on when you pull the trigger...which is a really good thing
(see below).
- portable, maneuverable, less tangly bits.
- low system complexity.
Disadvantages:
- no on/off switch for the heating element...why, oh why...?
- looks goofy.
- the flactuent sound the vacuum pump makes every time you pull the trigger will not win you
any friends and could possibly induce violence after periods of prolonged use.
This tool will not lessen the need for good solder braid skills but it is an awesome tool for fast, clean through hole component removal where the least amount of heat stress is applied to the contact surface and component leads.
