Tooki, Thanks!
Any idea what Rel0 means?
That’s the J-STD-004 flux classification. In this case, it means
REsin,
Low activity, halide-free.
The first segment is the base flux type:
ROsin,
REsin, or
ORganic
Rosin is the kind made from tree sap, resin is similar, but assembled from synthetic or refined resins, organic means acid based (in the context of electronics, that generally means water soluble fluxes)
The second is the activity level:
Low,
Moderate, or
High
Low and medium are common in electronics, but medium may require cleaning. High always requires cleaning AFAIK, but you’d only need that for extraordinarily corroded surfaces.
The number is whether it contains halides:
0 = halide free; 1 = contains halides
Halides make the flux work better, but can be conductive or corrosive, and thus may necessitate cleaning. Also less healthy to breathe in.
The most common types of non-water-soluble fluxes in electronics are probably REL0, REL1, ROL0 and ROL1, followed by the moderate equivalents.
Another classification system you often see, especially in USA, is the mil spec QQ-S-571E:
R: Rosin, not activated
RMA: Rosin or Resin, Mildly Activated
RA: Rosin or Resin, Activated (RA),
AC: non-rosin/resin (i.e. water washable)
Though the categories don’t line up exactly, a ROL0/ROL1/REL0/REL1 is roughly equivalent to RMA, while ROM0/ROM1/REM0/REM1 is roughly equivalent to RA. (Because the boundaries don’t line up exactly, it’s possible to have, for instance, a REM0 that falls under RMA and a different REM0 that falls under RA. Don’t hold me to this, though!)
Another classification system you often encounter is the ISO 9454-1 system, which uses a very granular system of numbers. Very broadly speaking, ROL0 is 1.1.1, ROM0 is 1.1.3, ROL1 and ROM1 are 1.1.2.W/X/Y; REL0 is 1.2.1, REM0 is 1.2.3, and REL1 and REM1 are 1.2.2.W/X/Y. (The letter suffixes specify very specific ranges of halide contents.)
And which of these dispensers is easier to work with?
http://www.chipquik.com/datasheets/SMD291NL-10M.pdf
Get the -10M, the “manual” syringe. Not only are they slightly cheaper at many distributors (I get it from Digi-Key), but the manual syringe lets you pull back on the plunger to stop flow. The non-manual syringe is the kind of tube actually intended for automatic dispensing systems. They do include a plunger with a little rubber cap that kinda grips into the actual plug in the tube, and while it does let you pull back a bit, you have to be very gentle or you’ll yank the rubber thing off. The manual tubes are just a tad easier to use.
