Author Topic: Comparator and oscillationS  (Read 2132 times)
Offline zanzeooTopic starter
« on: November 29, 2016, 07:16:18 pm »
Hi every !
I designed this circuit below , the purpose is to "convert" a signal from +/- 10Vac , 400Hz  , into a 0 - 5 Vdc .
I used an AD790 powered by a +/- 15 Vdc supply ,  the particularity of this comparator is the output which can be TTL ( see the datasheet) so Vlogic is 5 VDC .
I add a +/- 100 mV hysteresys with external resistors  , but it still oscillate a bit .
So wonder if i add a feedback capacitor , will it be better ?
How do you determine the value of the feed back capacitor ?
Thx
Sorry for my english
Re: Comparator and oscillationS
« Reply #1 on: December 10, 2016, 02:43:27 pm »
up
Offline danadak
« Reply #2 on: December 10, 2016, 03:13:59 pm »
Looks like you only have a couple mV of hysterisis
http://sim.okawa-denshi.jp/en/compkeisan.htm
Regards, Dana.
Offline Andy Watson
« Reply #3 on: December 10, 2016, 03:34:14 pm »
Have you applied all the recommendations given in the datasheet, specifically with regard to layout and "Bypassing and Grounding". What/how have you connected the latch input?
How do you know it is oscillating? - If you have applied an oscilloscope probe directly to the output of the AD970 the additional capacitance could be making the AD970 unstable - isolate the probe with 100-200\$\Omega\$ at the probe tip.
Offline mash107
« Reply #4 on: December 10, 2016, 03:58:51 pm »
Hi every !
Thx
As a rule of thumb, you don't want to limit the bandwidth of the positive feedback. It's not depicted in your schematic.. but say you had a noisy power supply that you're dividing down, and you had to add a large filter capacitor (in parallel with R4). Then you would need a cap like C1 to increase the bandwidth of the hysteresis. Otherwise it would be a large R (R1) charging a large C, and that might be too slow for the AC signal you want to convert. Let me know if that helps out.
Offline PChi
« Reply #5 on: December 10, 2016, 09:13:19 pm »
My experience of the AD790 is that it likes to oscillate at the transition even when care is taken with the layout and decoupling.
Are the decoupling capacitors right by the AD790 and are the connections to the inputs as short as possible to minimise the capacitive feedback?
Even with the hysteresis there might be a very short oscillation burst at the transistion.
