Author Topic: Desolder a crystallised solder joint  (Read 1545 times)
Offline _ar_Topic starter
  • Country: hu
« on: April 14, 2018, 05:55:03 pm »
Hello All,
I have a PCB with battery acid damage. I tried to desolder the battery pack and managed to do so for the 2 + terminal. However the - terminal's solder joint got the biggest hit from the battery. I just could not flow the solder no matter what I tried: used higher temperature, use a solder sucker, flooded the area with flux from a fluxpen, tried to heat both sides of the joint. Also tried to reflow the joint, but the solder barely melted, I could move it around somewhat and it would not take fresh solder. I ended up cutting the terminal. What is the best way to deal with such joints?
Thanks,
_ar_
« Last Edit: April 14, 2018, 05:56:57 pm by _ar_ »
Offline jmelson
Re: Desolder a crystallised solder joint
« Reply #1 on: April 14, 2018, 07:50:12 pm »
Dilute the solder with fresh solder, preferably SnPb or low melting point solder.  Possibly, somebody soldered it with high melting point solder in the past.  The fresh tin-lead solder should lower the melting point enough to make it possible to disassemble it.
Jon
