Author Topic: Detecting mains voltage  (Read 4996 times)
Offline aroby
« on: March 03, 2014, 07:00:42 pm »
Is there a simple way to detect when mains voltage is present?
I am going to put together a simple XBee-based remote switch.  The scenario is I have an existing in-wall digital timer to control outdoor lights and would like, when that timer turns on the lights, to activate another set of lights that are wired to power at a different location.  Getting the remote switching running is no problem, but what I need is a way for the source XBee to detect when the timer turns on/off the power - kind of like a reverse relay (since the XBee will already have power, I just need to apply that to one of the IO pins).
Clearly I have options such as connecting a small power supply to the switched side of the timer; or opening up the timer (which has an LCD display) and seeing if there is already a low voltage output.  Are there other approaches?  Is there such a thing as a relay that switches under mains voltage. Or an induction coil type of arrangement?
Thanks for any ideas
Anthony
Offline IanB
Re: Detecting mains voltage
« Reply #1 on: March 03, 2014, 08:02:17 pm »
You could do something simple like connect a neon lamp on the output of the timer and use a photo-detector on the input of the XBee to detect when the neon is lit?
Offline kripton2035
« Reply #2 on: March 03, 2014, 08:09:38 pm »
there are relays that need mains voltage to turn on, and then switch another mains voltage
search for 220v or 110v relays depending on your location.
Offline aroby
« Reply #3 on: March 03, 2014, 08:41:49 pm »
Interesting idea. That may also help with the need to separate the high and low voltage in the installation box.
Thanks
Offline Circuitous
    • Corgi-Tronics
« Reply #4 on: March 03, 2014, 09:44:37 pm »
There are plenty of opto isolators out there that will do this for you.
Just be sure to use a big enough resistor to limit the current and make sure it is flame-proof... I can't recall getting any other direction on that.
Also, check the isolation voltage of the opto, but it should be good enough, they're usually pretty high.
I don't recall the specific ones that I used, but I can check tonight if you need some specific part numbers.
The ones I chose have dual (reverse biased) LEDs, so that it picks up both halves of the cycle.
Offline sacherjj
« Reply #5 on: March 03, 2014, 10:38:30 pm »
I've used the LTV-354T from LiteOn for this and it works well.  You get pulses for all time, but zero crossing.  Which allows you to find zero crossing for free.  Just put in the correct current limiting resistors.  I was getting solid switching at < 2mA.
We switched to another smaller Opto, due to board size for the multi channel design.  Not finding that right now.
Offline Psi
« Reply #6 on: March 03, 2014, 10:57:13 pm »
i wonder if you could put a turn of the mains wiring around a floating ADC input and pickup the 50hz coupling to it.
Offline aroby
« Reply #7 on: March 04, 2014, 01:32:15 am »
Thanks for the suggestion.  If you have part numbers handy, that would be great, but I'll also scout around on Digikey and see what I can come up with.
Offline aroby
« Reply #8 on: March 04, 2014, 01:33:49 am »
I guess I should try that and see what happens!
Offline Psi
« Reply #9 on: March 04, 2014, 02:01:03 am »
Digital input should work too but will require more voltage swing to be detectable.
Offline Shock
« Reply #10 on: March 04, 2014, 03:05:34 am »
Just in case it hadn't crossed your mind.  If there is just one or two other switches is there any reason why you cannot wire it on a timer like the one you have already?
Programmable light switches run about $40, unless you absolutely need remote control I would take the easier route. Safer as well.
Multimeters: Fluke 87V, 117, 27/FM       >>> WANTED STUFF <<<
Offline BurtyB
    • 8086 Consultancy
« Reply #11 on: March 04, 2014, 12:54:22 pm »
The thread from a couple of weeks ago might give you some other ideas https://www.eevblog.com/forum/beginners/detecting-presence-of-mains/ .
Offline ConKbot
« Reply #12 on: March 04, 2014, 01:27:03 pm »
IIRC, in one of the teardown videos Dave did, a unit (I forget what) had a wire from the low voltage side heat shrunk to the insulated AC power wires to pick up mains.  Simple, and provides double isolation (cap the end of the pickup wire with small heat shrink before you heat shrink it to the AC wiring, not just a bare cut end)
Offline Stonent
« Reply #13 on: March 04, 2014, 02:00:28 pm »
I was thinking one of those cheap hardware store volt alert clones. When they buzz or light up, you can detect that.
Offline aroby
« Reply #14 on: March 04, 2014, 09:51:46 pm »
This is what I wanted to avoid!  I have several circuits around the property that I'd just like to activate from one timer.  So I don't have to change the on/off times on all the timers and keep them in sync.
Offline aroby
« Reply #15 on: March 04, 2014, 09:52:25 pm »
Thanks, I missed that one.
Offline aroby
« Reply #16 on: March 04, 2014, 09:53:40 pm »
That sounds exactly what I need.  Why didn't I think of that??  I think I need to take mine apart and see what's in there.
Offline IanB
« Reply #17 on: March 04, 2014, 10:14:38 pm »
I think you have to watch out for those detectors, they easily give false alarms. For instance all my non-contact voltage detectors believe my iPhone is live when the charger is plugged in.
Offline Psi
« Reply #18 on: March 05, 2014, 05:13:59 am »
That's because your iPhone is live when the charger is plugged in :P
