Author Topic: Anyone know of a good book on designing and understanding Battery chargers?  (Read 837 times)
Offline ve1nhbTopic starter
I know some of the theory. But I want to include rechargeable batteries in my projects and I want to learn to design my own.
Nelson (ve1nhb)
Nelson from the far eastern Island of Cape Breton.
Offline free_electron
    • SiliconValleyGarage
to build a charger you need to understand the battery. start there.
Offline anda3243
  • Country: cn
  • Product development professional, still learning
    • Check out our ThreadTitan product
I find this datasheet very informative. One little chip, and your battery is being charged.
https://www.analog.com/media/en/technical-documentation/data-sheets/405442xf.pdf
Overvoltage, overdischarge and overcurrent protection circuit is often included with the battery. But can be managed with the 2 attached chips.
Offline fordem
  • Country: gy
This is not true for all batteries - I have yet to see it on lead acid, Nicad or NiMH - or on single Lithium ion cells, yes it's common on lithium batteries that have been assembled into packs.
Offline Terry Bites
I doubt there is a book as such.  I'd be reading app notes and referrence designs from TI, AD, MICROCHIP, NXP, ONSEMI... eg https://www.maximintegrated.com/en/design/technical-documents/tutorials/4/4803.html
Remember that batteries can be dangerous if mishandled or electrically mistreated.
Offline tooki
Of course there are. A cursory search on Amazon finds numerous candidates.
With that said, all of the needed hands-on info can easily be found from the sources you mention, without forking out big bucks for a textbook.
That is the problem,  there are lots of books. But I can figure switch ones are good or bad without buying them and reading them.
I can build a basic circuit but I don't want to poke at something. I would rather learn from the ground up and play/build as I learn.
The whole idea is to have fun learning it.
