Author Topic: Determine speaker power wires polarity  (Read 3367 times)
Offline jotwerdeTopic starter
  • Country: bg
« on: October 31, 2018, 07:39:32 pm »
Someone gave me their speakers of which the power cable (cable from outlet to speakers) is cut at one point.
The separate wires of the cable are identical to each other (no distinct color of isolation or cables). The isolation is transparent and the wires are both silver-gray.
Is there a way to determine which wire to connect to which?
Does it even matter in the case of speakers?
Here's an (rather ugly) image to illustrate what I mean:
« Last Edit: November 03, 2018, 02:19:05 pm by jotwerde »
Offline helius
Re: Determine speaker power wires polarity
« Reply #1 on: October 31, 2018, 07:46:19 pm »
One wire is the Line, and the other is Neutral. In most cases they can be exchanged without any problem. In particular, equipment marketed in Europe should be perfectly safe because the CEE7/4 plug used in Germany can be inserted either direction.
This is a separate issue to the phase of speaker cables; in powered speakers, this issue doesn't crop up.
The following users thanked this post: tooki, jotwerde
Offline The Soulman
  • The sky is the limit!
« Reply #2 on: October 31, 2018, 08:05:56 pm »
Typical power cords are brown/blue on the inside are you 100% sure it is a power connection?
Do you have a (internet) picture of these speakers or a manufacturer name and model number/name that we can google ourselves
so that we all can sleep a little bit better?  :)
If it is mains connection than it shouldn't matter.
The following users thanked this post: jotwerde
Offline johnkenyon
« Reply #3 on: October 31, 2018, 08:09:44 pm »
In my experience, speaker wires are marked in one of three ways, different colours, white stripe, or moulded ridge on one side.
If your wires don't have any kind of colour code (e.g red+black, or black+black with white stripe), then use your fingers to touch the cable - specifically feel the side of each wire opposite where it joins the other wire - you will find one side will be round, and the other will have a ridge.
Poor ASCII art:
(o)(o>
o represents the copper core of each wire the other symbols represent the outer insulation.
Offline Audioguru
« Reply #4 on: November 01, 2018, 12:02:32 am »
The mains electricity plug was cutoff, not the speaker connection to its amplifier.
Modern plugs are polarized so that the widest blade is the Neutral connection. Then the Neutral wire connects to the non-sensitive power input to the amplifier in the speaker to avoid hum.
Offline JustMeHere
« Reply #5 on: November 01, 2018, 02:03:29 am »
Look at the main power switch.  If only one leg of the power is switched, it is the hot.  You might find some markings on the PCB.
Offline tooki
« Reply #6 on: November 01, 2018, 03:15:25 am »
Only on NEMA plugs.
European 2-prong plugs do not have any mechanism to enforce polarity (two identical round pins), nor do the most common European 3-prong plugs. (Within Europe, only the UK, Danish, French, and Swiss sockets enforce polarity on 3-prong plugs. However, because the French sockets are normally used with cords that are compatible with both the French- and German-style plugs, the latter of which does not enforce polarity, any appliance sold in Europe must accept either polarity without restriction.)
Offline tooki
« Reply #7 on: November 01, 2018, 03:18:31 am »
https://imgur.com/a/xsL8eFJ
So we are talking about the AC line cord for speakers intended for use in Europe? Then it doesn't matter. (Obviously, if it's a grounded cord, you must determine which is the ground.
Can you open the speaker housings? I'd recommend replacing the line cord if possible, instead of repairing it.
Offline JustMeHere
« Reply #8 on: November 01, 2018, 03:48:30 am »
You need to make sure the hot wire is switched off.  That does matter.
In the US single pole light switches go on the hot line.  If you do it the other way around it's against code.  You can be shocked if it's done backwards and your changing the bulb.
Offline tpowell1830
  • Peacefully retired from industry, active in life
« Reply #9 on: November 01, 2018, 04:01:53 am »
I guess I am to be the one to ask the OP.
Is this the speaker wires from the amplifier or is it your power cord wire to the speaker system that brings power from the wall?
If it is the power cord, then there is a right way to connect them (as explained multiple ways above). If it is the speaker wires from the amplifier, then it doesn't matter much.
PEACE===>T
Offline cdev
« Reply #10 on: November 01, 2018, 04:12:29 am »
If you are talking about speaker phasing, not power for amplified speakers, face the two speakers towards each other with the fronts facing one another but not touching, then put the source on mono and the right way to connect them is the way that sounds markedly louder.  Its best to use a wire where you can clearly tell one side from the other, just be consistent with both sides, yes it does matter a lot. All speakers sound like crap if they are wired out of phase.
Offline tooki
« Reply #11 on: November 01, 2018, 06:00:25 am »
Repeat after me: in Europe, the polarity is not enforced by the plugs, so every device with a plug must be made to be safe regardless of polarity. This is why in Europe, devices with plugs must be double-insulated. (The only way a device can be sure of polarity is to be hard-wired.)
The OP is in Bulgaria, which is part of Europe which uses the German-style socket, which does not enforce polarity even for grounded plugs. So any appliance used there MUST be designed to be safe with either polarity.
For all intents and purposes, the Americas are the only place that still relies on polarized 2-prong AC plugs for safety in any way. (I suppose the Australian plug enforces polarity, not sure if they allow devices to rely on it, though.) But since more and more products are designed for world compliance anyway, they just properly double-insulate anyway.
And why are you even bringing up light switches and sockets? We aren't talking about house wiring, where things must be done accurately. This is a plug-in device, which must comply with different standards separate from household code.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #12 on: November 01, 2018, 09:46:17 am »
that doesnt matter...
Offline IanMacdonald
    • IWR Consultancy
« Reply #13 on: November 01, 2018, 09:56:32 am »
Are you talking about signal leads from an amplifier, or a mains lead to powered (active) speakers?
Kinda important as if you get this one wrong you'll destroy them.
Active speakers will also have some other signal input socket, such as a Cannon XLR or 1/4" jack. They will also have a rating plate stating the allowed mains voltage range.
  • Country: bg
« Reply #14 on: November 01, 2018, 06:54:28 pm »
First, I wanna thank everyone for taking the time to post a reply.
Mains, thought this was illustrated in the image (by showing the plug at the one end). Am I maybe misunderstanding something?
I live in Europe.
It's a Type C plug (can be seen in the pic, maybe did't make it clear/good enough, sorry). No blades at all.
Poor ASCII art:
(o)(o>
It's the cable with the speakers at one end and the plug intended to be plugged into the wall socket on the other. It has to be the power connection.
But the wires are both similar (look and feel).
Here's a pic (or two):
From tooki and Mechatrommer's answers I gather that it's safe in this case to connect the wires to either ones of the others, right?
« Last Edit: November 03, 2018, 09:59:04 am by jotwerde »
Offline Richard Crowley
  • KJ7YLK
« Reply #15 on: November 01, 2018, 07:15:13 pm »
If it is the common CEE 7/16 Alternative II "Europlug" (Type C), then
Because it is unpolarised, it can be inserted in either direction into a socket, so line and neutral are connected arbitrarily.
Ref: https://en.wikipedia.org/wiki/AC_power_plugs_and_sockets#CEE_7/16_Alternative_II_%22Europlug%22_(Type_C)
The fact that it happens to be powering speakers is irrelevant to the discussion if you are talking only about the power mains cord/plug.
That is what caused confusion at the beginning of this discussion.
« Last Edit: November 01, 2018, 07:17:08 pm by Richard Crowley »
Offline Zero999
  • 0999
« Reply #16 on: November 01, 2018, 08:52:53 pm »
jotwerde,
Please attach the image, rather than using a hosting site. I was at work on my coffee when I saw this and the site was blocked by the firewall, so I didn't respond.
Yes, the polarity of the mains is unimportant. It's AC and goes through a bridge rectifier, resulting in DC of the correct polarity.
  • Country: bg
« Reply #17 on: November 02, 2018, 08:02:40 am »
jotwerde,
Corrected the images. Was using the wrong sharing link, sorry.
I don't like using attachments, using a hosting site and embedding the image is cleaner (at least when done right).
Thanks for mentioning the bridge rectifier. Very insightful.
« Last Edit: November 02, 2018, 09:46:17 am by jotwerde »
Offline Zero999
  • 0999
« Reply #18 on: November 02, 2018, 10:48:53 am »
jotwerde,
Now I can't see anything, as the firewall is blocking the image.
It's possible to embed an attachment in a post. Attach the image, as usual, post it, click the attachment's thumbnail to open the image, copy the image location (the procedure for this, depends on what browser you're using), edit the post and paste the image's URL into the post between [img] tags.
See the following thread for more information:
https://www.eevblog.com/forum/chat/how-to-include-images-in-a-post/msg298580/
  • Country: bg
« Reply #19 on: November 03, 2018, 10:04:03 am »
Ok, thanks, I'll keep that in mind for future posts.
  • Country: my
« Reply #20 on: November 03, 2018, 12:03:47 pm »
I just saw your drawing in op. Its kinda strange. How can 1 wire for each speaker?
Offline bob225
« Reply #21 on: November 03, 2018, 12:22:44 pm »
It seem like there is some confusion, so you want to know what's live and what's neutral ?
Its a AC input the plug is not polarised or earthed so polarity shouldn't matter (like a electric razor)
does the item have a fuse on the rear of it ? if so that will be live, trace it with a meter
The biggest question no one has asked, why was the plug chopped off in the first place ???? that sort of lead screams cheap Chinese cable ( copper coated aluminium )
  • Country: bg
« Reply #22 on: November 03, 2018, 02:15:25 pm »
Oops, that's a mistake. My fault.
« Last Edit: November 03, 2018, 02:17:26 pm by jotwerde »
