Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Did I buy the wrong eprom programmer?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Did I buy the wrong eprom programmer? (Read 855 times)
cypher007
Contributor
Country:
on:
May 09, 2020, 06:17:11 pm »
i recently bought a tl866a. i then began to regret this decision as it seems the tl866ii plus is better? i will use mine for laptop bios repair so 1.8v, 27c400 for my amigas, and some other older 8bit roms.
have i bought the wrong one?
Logged
james_s
Super Contributor
Country:
Re: Did I buy the wrong eprom programmer?
Reply #1 on:
May 09, 2020, 06:28:55 pm »
The II is newer, it's possible that it's better, but the older model is just fine. If it supports the chips you need to program then there's no reason to regret it. I have an older TL866 that I've been very happy with.
Logged
cypher007
Contributor
Country:
Reply #2 on:
May 09, 2020, 09:32:51 pm »
ive bought this to hopefully flash newer 1.8v bioses
https://www.ebay.co.uk/itm/1-8v-ADAPTER-v2-0-MOTHERBOARD-MX25U1635-MX25U6435-MINIPRO-TL866-SKYPRO/114021334031?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
i did notice a youtuber who bought a tl866ii plus and it had an extra square chip adapter with it. i might try and dump some early 90's gals that i have on an accelerator. im not sure if the 4 i have will be the right size. i guess i can maybe buy it separately.
im just looking for the widest compatibility. i suppose the fact the tl866a does 21v compared to the tl866ii 18v.
Logged
Shock
Super Contributor
Country:
Reply #3 on:
May 10, 2020, 02:05:38 am »
Ideally get both just for compatibility and programming voltage, but you can hold off on the newer model until you need it.
You probably also brought a lookalike clone as they stopped making the original a while back. You may need to flash a valid serial into it if it complains on the latest firmware that it's not genuine,
discussed in this thread
The good news is since the original has been reverse engineered they can easily be repaired and recovered if they fail.
Logged
Multimeters: Fluke 189, 87V, 117, 112
>>> WANTED STUFF <<<
james_s
Super Contributor
Country:
Reply #4 on:
May 10, 2020, 03:42:14 am »
The list of supported chips is published, and you can also download the software and load it without the programmer to see what's there. If the chips you want to flash are in the list then it will do the job.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
