Author Topic: freeware electrical block diagram software?  (Read 6101 times)
Offline wblackledgTopic starter
« on: April 03, 2015, 05:46:49 pm »
I'm working on building a control panel for a sump pump backup system.
I was wanting something I could diagram the wiring setup (pump, battery, charger, alarm, switches, AC mains, Ground, etc.)
I have DipTrace (am brand new to it) , but that seems pretty low level for a high level wiring panel diagram, or am I wrong?
The software doesn't have to anything fancy like find wiring faults (although that would be kind of cool),   just something I can visually pound out whats in my head.
thanks
« Last Edit: April 03, 2015, 05:55:01 pm by wblackledg »
Offline Neganur
Re: freeware electrical block diagram software?
« Reply #1 on: April 03, 2015, 10:14:44 pm »
I had a similar problem last year, I found that you end up spending more time looking for a software than taking something like an evaluation version of Microsoft Visio and just draw the symbols yourself.
Offline codeboy2k
« Reply #2 on: April 03, 2015, 10:35:36 pm »
Try the online tool www.draw.io
or http://www.digikey.com/schemeit
Inkscape
yEd  :  http://www.yworks.com/en/products_yed_about.html
Lucid Chart  (maybe not free)
Openoffice Draw
Dia
not free, but Autocad Electrical has everything you will need.
« Reply #3 on: April 03, 2015, 11:27:42 pm »
I thought about that.   ;D
I noticed Visio doesn't come with MS-Office.  :-\
Worst case i just sketch it out by hand on paper and pencil.  :P
« Reply #4 on: April 03, 2015, 11:42:40 pm »
Inkscape
Openoffice Draw
Dia
very cool.  I should be able to find something that works.
thanks.
Offline Neganur
« Reply #5 on: April 04, 2015, 12:41:50 am »
60 days trial IIRC
digikey's schemeit can't scale anything and is not designed to do that (according to support they don't plan to add that either)
yEd proved useful for a different project, can recommend that thing.
« Last Edit: April 04, 2015, 12:47:12 am by Neganur »
« Reply #7 on: April 04, 2015, 12:53:37 am »
60 days trial IIRC
thanks.
Offline Lightages
  • Canadian po
« Reply #8 on: April 04, 2015, 12:59:43 am »
For electrical diagrams I found this to be simple and fast to learn and use..
https://www.proficad.com/
« Reply #9 on: April 04, 2015, 01:05:39 am »
very cool.  thanks.
I'll check into it.
Offline mtdoc
« Reply #10 on: April 04, 2015, 01:06:11 am »
That looks like a great free tool. Thanks!.
Offline Fsck
  • sleep deprived
« Reply #11 on: April 12, 2015, 07:44:53 pm »
amigod, it's brilliant yet simple.
"This is a one line proof...if we start sufficiently far to the left."
Offline Chiaroscuro
« Reply #12 on: April 12, 2015, 08:46:06 pm »
What about student version? Aren't they usually free with Autocad?
