Author Topic: [SOLVED] Looking for a supplier for 1.27mm Pin Headers - Pics in post  (Read 1192 times)
Offline castingflameTopic starter
Due to space restrictions I have had to use some 1.27pitch THT Pin headers. I am now looking for a more resaonable supplier cost wise. RS in the UK are over £2 for each connector, Farnell is Worse. Toby is a even more expensive £2.79. The best so far has been Ali-Express and there are only 2 sellers but even then they work out £1 each. If I have too I will go to AliExpress but the time delay for post/cost of post will be an issue.
Anyone have any ideas for suppliers for these connectors? I am in the UK ... if that makes any difference.
In a perfect world I would prefer the low profile version (not so tall) that I have seen of these.
Cheers.
EDIT:    tme.eu    are cheapest so far at £0.90  &   £0.62      less VAT and del.
« Last Edit: June 08, 2020, 08:03:32 am by castingflame »
Offline knapik
Re: Looking for a supplier for 1.27mm Pin Headers - Pics in post
« Reply #1 on: June 05, 2020, 01:46:23 pm »
You might be able to save a bit with LCSC if you decide to use surface mount instead of through hole. The male ones come in a bag without pick and place caps though.
The following users thanked this post: castingflame
Offline jc101
« Reply #2 on: June 05, 2020, 06:11:10 pm »
I'm surprised Toby is that much for what looks like a 10x2 1.27mm pitch pin header (as an example TMS-110-02-G-D is £0.95 in singles), what parts are you looking at?
If you're a company, the likes of Wurth will sell direct to you - but they charge shipping.  Roughly, you end up paying about half the price of a distributers right hand column (high quantity) count even for single items.
Offline ebclr
« Reply #4 on: June 07, 2020, 09:06:39 pm »
Thanks for the replies guys. In the end I went with AliExpress and they ended up at 34p as opposed to £2.50 from RS for the female and similar ratio reduction for the male. Still expensive when compared to the 10p and less for 2.54mm pitch equivalent but more manageable to buy a quantity of ahead of building some boards.
Cheers.
« Reply #5 on: June 07, 2020, 09:08:36 pm »
Oh and I had to use THT because of space restrictions in width and height of connector. 10th of millimeters counted.
Offline ebclr
« Reply #6 on: June 07, 2020, 09:53:07 pm »
Also, take a look at the 2mm ones, They are smaller than the 2.54 mm and easy to handle than the 1.27mm
« Reply #7 on: June 08, 2020, 08:01:38 am »
Yes I had a look at those but unfortunately they were too high when combined.
Offline c64
I also want to use 1.27 connector (between two boards) or something with similar pitch. 2.54 is too big. It will be used frequently, so I think SMD one will not last long.
I found few but the pins are very dense and can not fit a trace between the pins (I need connector with two rows of pins). Anyone can recommend anything?
« Last Edit: June 29, 2020, 05:38:28 am by c64 »
