Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Difference between a resistor and voltage divider in these two examples
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Difference between a resistor and voltage divider in these two examples (Read 573 times)
Youkai
Regular Contributor
Country:
on:
May 10, 2020, 05:31:01 am »
I was watching some Youtube videos about DFPlayer Mini modules with Arduino and came across these two examples. The data pin of that module needs less than 5v to operate properly. One uses a resistor to accomplish this and the other uses a voltage divider. Links are timestamped to the appropriate point in the video.
Resistor example:
https://youtu.be/UodfePdNfg8?t=105
Voltage divider example:
https://youtu.be/P42ICrgAtS4?t=41
What if any is the difference in these two approaches? Is one better than the other?
Logged
ataradov
Super Contributor
Country:
Re: Difference between a resistor and voltage divider in these two examples
Reply #1 on:
May 10, 2020, 06:19:00 am »
Series resistor limits the current that protection diodes inside the module will have to handle.
The divider is just that - a divider.
The divider is generally better. A proper level shifter is even better.
Logged
Alex
gbaddeley
Regular Contributor
Country:
Reply #2 on:
May 10, 2020, 10:42:48 am »
If the load current varies, a divider will provide better regulation. If the load current is constant (within a few %), the series resistor is just as good as a divider, and has fewer parts, with less heat dissipation.
Logged
Glenn
Youkai
Regular Contributor
Country:
Reply #3 on:
May 11, 2020, 05:03:19 am »
Is it safe to assume that the current supplied by an Arduino (or clone) pin is constant and the series resistor is fine here?
Logged
ataradov
Super Contributor
Country:
Reply #4 on:
May 11, 2020, 05:07:29 am »
It is not about supplied current. It is about consumed current.
And the calculation for the series resistor value is defined by the current handling capability of the protection diodes.
Generally go with the divider, it is much safer way to operate those devices.
Logged
Alex
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
