Author Topic: On-line UPS - how to check it is faulty or not without batteries  (Read 2764 times)
Offline dvasTopic starter
  • Country: il
« on: February 02, 2014, 12:37:58 pm »
I got a True on-line UPS that looks like being in superb condition, but it is without batteries. I managed to locate the attached document (I removed some non-relevant pages due to doc size) and I found out it runs from 8x 12VDC batteries. Now, I don't have those batteries laying around just for test and I don't know how to test this beast without them.
If the UPS is OK, I will be gladly purchase them, but not just for test.
Any help is appreciated to help me do the basic troubleshooting if it is working or not.
Systel ON-LINE PM1500 UPS
Needless to say, when connected to mains, it looks dead.
thanks,
Sasha
Re: On-line UPS - how to check it is faulty or not without batteries
« Reply #1 on: February 02, 2014, 12:48:49 pm »
No obvious blown parts, just plug it in and see if it complains about battery fault. If so then it is likely to be working, and you can get 8 7Ah SLA batteries and test it.
  • Country: il
« Reply #2 on: February 02, 2014, 12:52:16 pm »
thanks Sean for quick reply, but when plugged in, nothing is happening... dead.... no LEDs, no beeps,.....
« Reply #3 on: February 02, 2014, 01:36:15 pm »
So it needs the battery to bootstrap then. You need a power supply that can deliver the required 90VDC it needs then it should start up and complain with no mains connected. If not then it is spare parts.
  • Country: il
« Reply #4 on: February 02, 2014, 01:40:56 pm »
that is my problem. how to get 96VDC supply.
another option was that I scrap from different UPSs around some batteries and to ask friends for some more.
Offline dr.diesel
« Reply #5 on: February 02, 2014, 01:44:23 pm »
Variac, rectifier and a few caps?
« Reply #6 on: February 02, 2014, 01:52:05 pm »
And hot gloves.......
  • Country: il
« Reply #7 on: February 02, 2014, 01:52:14 pm »
possible. I will see what can i easily get....
Offline dr.diesel
« Reply #8 on: February 02, 2014, 01:55:48 pm »
Do be careful, DC is much more dangerous, especially if you got across both the positive and negative leads.
