Author Topic: Difference between MSO & LA with scope  (Read 2374 times)
Offline JoeBean
« on: March 08, 2011, 03:44:00 pm »
Probably a simple and/or dumb question, but what, if anything, is the difference between a mixed signal oscilloscope and a logic analyzer with a built in oscilloscope?   I missed out on a fairly new Agilent MSO for a good price a little while ago, and since then I've seen some Agilent 16xx series LA come up on ebay for cheap and I was just wondering why 2 seemingly similar creatures would have different names.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Difference between MSO & LA with scope
« Reply #1 on: March 08, 2011, 06:12:24 pm »
Mostly marketing. The old 16xx HP's were basicallys LA's with scope add-on options, so the user-interface is likely to be more LA-like than a scope - a lot of the old HP scopes had poor user interfaces generally. The MSO name appeared when HP launched the 54645D which was a scope with digital channels and wanted a buzzword to distinguish it.
Day Job: Mostly LEDs
Alex
  • Guest
« Reply #2 on: March 08, 2011, 08:42:10 pm »
I would also suspect that the function that is mentioned second is slimmed down.
An MSO will be a better scope than a its logic analyser in the same way there is more pasta in 'pasta with sauce'. lol
« Last Edit: March 08, 2011, 11:27:02 pm by Alex »
Offline JoeBean
« Reply #3 on: March 08, 2011, 11:08:56 pm »
OK, that history helps make sense of it. Thanks.
An MSO will be a better scope than a logic analyser in the same way there is more pasta in 'pasta with sauce'. lol
Isn't that always how it is?  Just like Mixed Nuts With [insert expensive nuts] are always 99% peanuts with 2 of the other nuts broke up and hiding in the bottom.  ;D Anyway, didn't mean to get off topic...
