You need to know the load capacitance of a crystal. I see nothing in that listing and I suspect that information won't be included. Just order an assortment of e.g. Abracon crystals from a reputable distributor. Basic jellybean crystals are not expensive.
What reputable distributor do you know? This distributor available samples, like microchip for example?
I am a newbie on electronics, do you refer this,
https://www.foxonline.com/pdfs/xtaldesignnotes.pdf , when talk about load capacitance of a crystal?
Load Capacitance
This refers to capacitance external to the crystal,
contained within the feedback loop of the oscillator
circuit. If the application requires a "parallel" resonant
crystal, the value of load capacitance must be specified.
If the application requires a "series" resonant crystal,
load capacitance is not a factor and need not be specified.
Load capacitance is the amount of capacitance measured
or computed across the crystal terminals on the PCB.
How many different crystals do you need? I find that 2 or 3 different values cover 99% of my needs.
To right now I only need 4MHz and 16MHz, but to reduce breakages I prefer to gather a variety of values, to avoid problems in a future.
Thanks
