I want to build a project, tiny sensor station that is powered by solar power and radios its result to nearby base station (just nrf24l01, nothing fancy). Basically micro will sleep for most of the time and occasionally (when there is enough power left in cap), send a burst of data with sensor info.
So I need about 3.3V 20-30mA peak, with few uA on standby and tolerance to low/high temperatures. From what I've calculated *basically* I need enough storage to get it thru the night which at the vey worst case is around 12 hours
So it seems to me that slapping a supercap on it is not a bad choice as I don't want to really bother with changing batteries or want to include charging circuit
From what I've calculated having 1F cap discharging from 5.1V to 3.4V (I just want to slap a zener in to control the voltage, but chip with dedicated cap circuit could just go 5.4V) would allow for around 40uA of average current, which seems doable as micro in standby only takes around 1uA with 32khz timer running and I dont plan on running radio at night (or batch measurements and run at reduced rate).
Question is... how ?
I've looked into dedicated chips like LTC3105 but they seem to be overkill on price (but separate outputs and power good would be handy), and a bit big on quiescent current, also no step-up from supercap so it still wastes quite a bit of its capactity.
From what I've calculated just using LDO MCP1711 would be not only MUCH cheaper (well I doubt I will make more than 10 of those but still) but savings on Iq alone would be worth it. But that's still whole lot of wasted capacity.
So I've started looking into DC/DC converters. I need 3.3 from 5.1 to(preferably) around 1V (but it doesn't need to start from that) so I need SEPIC/buck-boost converter (forgive me if I fucked up something, never really builded a DC/DC converter into anything yet)
LT1615 looked interesting at first sight but 20 uA Iq and "costs more than micro I used" not so much
I've also looked into microchip ones but all of the low Iq seem to be of boost type. Digikey/mouser dont have Iq on parametric search so I dont really know where to look for next
