The main difference about a flyback, is that it doesn't transfer energy to the secondary continuously. A pulse current charges the magnetic
field in the core, then when it stops and collapses (and resets the core), only then does the secondary coil move current into the load.
Thus the core needs to build to a significant magnetic field. This very high current pulse in the primary is bad for power factor, when
drawn from a AC supply. Of course this must be done at a high speed,
not at 50/60Hz of an old iron transformer
