I found the problem. I will write the solution here, probably it will be useful to someone.
The max6675 module needs to be read at a minimum interval of 250mS. Please have a look at this code, were is a comment that explains the mentioned time interval:
https://github.com/adafruit/MAX6675-library/blob/master/examples/serialthermocouple/serialthermocouple.inoThen I modified the code as shown below:
#include <PID_v2.h>
#include <max6675.h>
//MAX6675 module data pins
int thermoDO = 12;
int thermoCS = 10;
int thermoCLK = 13;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
//Protection pins
int relay_pin = A2;
//int led_pin = 8;
//This array contains what segments need to be turned on to display numbers 0-9
byte const digits[] = {
B00111111, B00000110, B01011011, B01001111, B01100110, B01101101, B01111101, B00000111, B01111111, B01101111
int digit_common_pins[] = {A3, A4, A5}; //Common pins for the triple 7-Segment LED display
int max_digits = 3;
int current_digit = max_digits - 1;
unsigned long updaterate = 700; //Change how fast the display updates. No lower than 500
unsigned long lastupdate, lastupdate_max;
int temperature = 0;
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
double heaterTemp;
//Define the aggressive and conservative Tuning Parameters
double aggKp = 4, aggKi = 0.2, aggKd = 1;
double consKp = 1, consKi = 0.05, consKd = 0.25;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
void setup()
DDRD = B11111111; // sets Arduino pins 0 to 7 as outputs
for (int y = 0; y < max_digits; y++)
pinMode(digit_common_pins[y], OUTPUT);
//We do not want to drive the soldering iron at 100% because it may burn, so we set it to about 85% (220/255)
myPID.SetOutputLimits(0, 220);
myPID.SetMode(AUTOMATIC);
lastupdate = millis();
lastupdate_max = millis();
Setpoint = 0;
//pinMode(led_pin, OUTPUT);
pinMode(relay_pin, OUTPUT);
//digitalWrite(led_pin, LOW);
digitalWrite(relay_pin, LOW);
delay(1000);
digitalWrite(relay_pin, HIGH); // turns on the relay to let the current flow to the soldering iron heater
void loop() {
if (millis() - lastupdate_max > 250){
// Read temperature
heaterTemp = thermocouple.readCelsius();
Input = (0.779828 * heaterTemp) - 10.3427; //estimate the temperature of the iron's tip, by reading the temperature of the iron's heater
//Display error
if (isnan(heaterTemp) or Input >= 432) // No TC Connection OR over-temperature
while (true) {
digitalWrite(relay_pin, LOW);//cuts off the power to the soldering iron
digitalWrite(11, LOW);//turns off the PID output
PORTD = B00000000; // Turns off the entire display
//digitalWrite(led_pin, HIGH);
//Display temperature
if (millis() - lastupdate > updaterate) {
temperature = Input;
//Read setpoint and transform it into degrees celsius(minimum 150, maximum 400)
double newSetpoint = analogRead(A1);
newSetpoint = map(newSetpoint, 0, 1023, 150, 400);
//Display setpoint
if (abs(newSetpoint - Setpoint) > 3) {
Setpoint = newSetpoint;
temperature = newSetpoint;
double gap = abs(Setpoint - Input); //distance away from setpoint
if (gap < 10)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
else
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute(); // compute the pid output
//Drive the output
analogWrite(11, Output);
//Display the temperature
if (temperature < 50) {
show(50); //display 50 if the estimated temperature is below 50C
else
show(temperature); //display the temperature
void show(int value) {
int digits_array[] = {};
boolean empty_most_significant = true;
for (int z = max_digits - 1; z >= 0; z--) //Cycle through each digit
digits_array[z] = value / pow(10, z); //We now take each digit from the number
if (digits_array[z] != 0 ) empty_most_significant = false; //Do not display leading zeros
value = value - digits_array[z] * pow(10, z);
if (z == current_digit)
if (!empty_most_significant || z == 0) { //Check to see that we do not have leading zeros and display the current digit
PORTD = digits[digits_array[z]]; //Remove ~ for common cathode
else
PORTD = B00000000;
digitalWrite(digit_common_pins[z], HIGH);//Change to LOW for common cathode
} else {
digitalWrite(digit_common_pins[z], LOW);//Change to HIGH for common cathode
current_digit--;
if (current_digit < 0)
current_digit = max_digits; //Start over
I tested the code and it seems to work good...
