Author Topic: Triac Dimmer  (Read 4285 times)
Offline JblissTopic starter
Triac Dimmer
« on: December 26, 2015, 09:41:15 am »
Here is the Circuit I have built however its not working can some one please help explain what I'm doing wrong
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Triac Dimmer
« Reply #1 on: December 26, 2015, 10:07:53 am »
The resistors feeding the triac gate should come from the power directly and not through the load.
Re: Triac Dimmer
« Reply #2 on: December 26, 2015, 10:17:08 am »
all the circuits i have seen show the Resistors after the load ?
Re: Triac Dimmer
« Reply #3 on: December 26, 2015, 10:23:25 am »
Just tried it and made no differences  :( :(
Re: Triac Dimmer
« Reply #4 on: December 26, 2015, 10:38:25 am »
Triac connections are wrong.. The triac gate has a reference, in this case pin 1. Using the other way round it likely will either be on always  or off, depending on the capacitor charging.
http://www.nxp.com/documents/data_sheet/BT136_SERIES.pdf
Note the gate is referenced to MT1, thus you must always apply the trigger with reference to this.
Read this golden rules as well, will help you understand more.
http://www.nxp.com/documents/application_note/AN_GOLDEN_RULES.pdf
« Last Edit: December 26, 2015, 10:41:52 am by SeanB »
Re: Triac Dimmer
« Reply #5 on: December 26, 2015, 01:20:04 pm »
so it show be connected around the other way so MT2 is connected to the positive
Offline MagicSmoker
Re: Triac Dimmer
« Reply #6 on: December 26, 2015, 07:19:59 pm »
There is no "+" terminal on the mains, but judging by the naming of one terminal as "N" it seems you are in the USA, yes?
The RC values are more appropriate for a 230VAC/50Hz dimmer circuit - try reducing the fixed resistor to 3.3k and the capacitor to 100nF (note that it should be a high voltage film type for safety reasons). Other possible problems are: bad or miswired pot (center and right terminals, with knob facing you); 10k resistor not really 10k (too high or open circuit); diac breakover voltage too high (needs to be around 30V); bad triac; shorted capacitor; insufficient or missing or highly inductive load present - this dimmer circuit will not work without a predominantly resistive load (like a... wait for it... incandescent lamp!).
Incorrect. Triacs can be triggered by any combination of gate polarity with respect to MT1 (T1) or MT2 (T2) polarity. See relevant excerpt from the BT136 datasheet you posted:
Re: Triac Dimmer
« Reply #7 on: December 27, 2015, 12:17:48 pm »
Not america in australia Mains voltage is 240
Re: Triac Dimmer
« Reply #8 on: January 07, 2016, 01:30:23 pm »
ok came back to the circuit today still not working any help out.
ty
Offline alsetalokin4017
Re: Triac Dimmer
« Reply #9 on: January 07, 2016, 09:52:50 pm »
You might want to take a look at this page:
http://www.circuitstoday.com/simple-lamp-dimmer-fan-regulator
Offline Paul Moir
Re: Triac Dimmer
« Reply #10 on: January 08, 2016, 02:02:56 am »
A 10k pot and 500k limit resistor seem backwards.  Like the pot should be a much higher value and your current limit much lower.  In your original schematic, it looks like you have a 500k pot, but your symbols are not clear.  500k likely prevents the TRIAC from ever turning on.  10k probably isn't enough adjustment range to notice.
PS - probably helpful:  is your load always off or always on?  What TRIAC?
« Last Edit: January 08, 2016, 02:07:16 am by Paul Moir »
Offline SL4P
  • There's more value if you figure it out yourself!
Re: Triac Dimmer
« Reply #11 on: January 08, 2016, 03:32:40 am »
Also assuming you have a DIAC in position D1 (DB2)
Anything else will have unexpected consequences.
Don't ask a question if you aren't willing to listen to the answer.
