Author Topic: Replacing trim pot with multi turn on buck regulator  (Read 1237 times)
Offline StuartambientTopic starter
« on: November 15, 2016, 02:34:50 pm »
I bought a relatively inexpensive 10 turn pot for a buck regulator (pic attached).  Made the mistake of not seeing the power rating of 2W on the 10 turn when I ordered it. I'm wondering if the power produced though would actually be running through the pot?  Currently I run the regulator up to around 3Watts.  Seems to work fine and I don't imagine (i could be wrong) that the trim pot has much of a power rating either.  I do expect to generate more power with some other applications, ~6-7W.
If the circuit though has all the power going through the pot maybe I should look for something with a higher rating? I know the picture doesn't show the actual circuit but maybe it helps.
TIA
Offline Ysjoelfir
Re: Replacing trim pot with multi turn on buck regulator
« Reply #1 on: November 15, 2016, 03:19:52 pm »
You are totally fine with your 10 turn 2W pot, those tiny trim pots used on the original design are useable for up to a few mW, i would guess 250mW max.
The power will go in no way through the pot, they are only used with signal levels. So - keep it the way you do right now, there shouldn`t be any problem at all.
Greetings, Kai \ Ysjoelfir
The following users thanked this post: Stuartambient
« Reply #2 on: November 15, 2016, 06:00:39 pm »
Excellent, thank you!
