Author Topic: increasing current peak for MC34063?  (Read 1614 times)
Offline willbanksTopic starter
« on: June 26, 2017, 01:01:23 am »
I made a circuit that reduces 12V to 5V using the MC34063. I set it so it will provide 1 amp of current. The peak current is 2 amps, which is above the maximum current (1.5A).
Could I increase the current if I put the 5V output to an LM317, which could provide that current boost?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: increasing current peak for MC34063?
« Reply #1 on: June 26, 2017, 08:45:42 am »
Seven Transistor Labs, LLC
« Reply #2 on: June 27, 2017, 01:19:05 am »
$7 for a chip? hell no
Offline T3sl4co1l
« Reply #3 on: June 27, 2017, 09:54:22 am »
$7 where?
