Author Topic: Differential Probe Output Cable Impedance - Does it matter?  (Read 1121 times)
Offline nidlaXTopic starter
Out of curiosity, does it matter what type of BNC cable is used for the output cable of a (<200 MHz) differential probe? Most manufacturers don't even specify whether they use 50 Ohm or 75 Ohm cable, but I'm guessing 50 Ohm is the standard.
Offline tautech
Re: Differential Probe Output Cable Impedance - Does it matter?
« Reply #1 on: June 27, 2017, 08:01:41 am »
Probably won't matter for LF stuff but they will be 50 \$\Omega\$ that matches channel input impedance when 50 \$\Omega\$ input is selected.
Avid Rabid Hobbyist
Offline capt bullshot
« Reply #2 on: June 27, 2017, 08:09:56 am »
I wouldn't consider 200MHz LF stuff ...
And I'd expect the cable to have 50 Ohms.
Offline tautech
« Reply #3 on: June 27, 2017, 08:15:13 am »
Neither do I. Maybe I should've stated a few 10's of KHz.
Avid Rabid Hobbyist
