Author Topic: Digikey's cap. conversion calculator is wrong when converting nF to Farads?  (Read 1782 times)
Offline akos_nemeth
  • Country: hu
Hi All,
I tried to convert 100nF to Farads, and I think it is 100/1 000 000 000 = 1 * 10 -7, but Digikey's calculator (http://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-capacitance) says it is 1*10-8.
An other calculator (http://www.unit-conversion.info/capacitance.html) says it is 1 * 10 -7. So I guess nobody noticed, since nobody uses Farads for anything practical?
First image is a screen capture from the Digikey calculator's result, the second is from the result of the "Capacitance Unit Converter".
Regards,
Ákos
Online MK14
If you look at the code (view page source, JavaScript), there seems to be one too many zeros, on line 271.
if (pOption == "nF") {
   document.getElementById("nF1").value = pIn;
   document.getElementById("uF1").value = parseFloat((pIn * 0.001).toFixed(12));
   document.getElementById("F1").value = parseFloat((pIn * 0.0000000001).toFixed(12));
   document.getElementById("pF1").value = parseFloat((pIn * 1000).toFixed(12));
if (pOption == "pF") {
document.getElementById("pF1").value = pIn;
document.getElementById("uF1").value = parseFloat((pIn * .000001).toFixed(12));
document.getElementById("nF1").value = parseFloat((pIn * 0.001).toFixed(12));;
document.getElementById("F1").value = parseFloat((pIn * 0.000000000001).toFixed(12));
if (pOption == "uF") {
document.getElementById("uF1").value = pIn;
document.getElementById("nF1").value = parseFloat((pIn * 1000).toFixed(12));
document.getElementById("F1").value = parseFloat((pIn * 0.000001).toFixed(12));
document.getElementById("pF1").value = parseFloat((pIn * 1000000).toFixed(12));
if (pOption == "F") {
document.getElementById("F1").value = pIn;
document.getElementById("uF1").value = parseFloat((pIn * 1000000).toFixed(5));
document.getElementById("nF1").value = parseFloat((pIn * 1000000000).toFixed(5));
document.getElementById("pF1").value = parseFloat((pIn * 1000000000000).toFixed(5));
Online Benta
Who cares about Digikey?
My HP15C gets it right every time  ;D
Offline akos_nemeth
  • Country: hu
Hi MK14,
I have sent them a mail, with your finding this will be a very easy ticket for the web developer.  ;D
Regards,
Ákos
The following users thanked this post: MK14
Online MK14
Hi MK14,
Regards,
Ákos
Thanks for doing that!
I hoped you would, and toyed over suggesting that in my original post.
Online mikeselectricstuff
    • Mike's Electric Stuff
Digikey always seem to have  had a problem acknowledging that nanofarads are a thing
Day Job: Mostly LEDs
Online Zero999
  • 0999
I've never seen the point in those calculators. I can perform the conversion in my head faster than typing the numbers in.
For some reason, nF is less common in the states than Europe. I don't know why. It's certainly neater to write 4.7nF than it is to write 4700pF, 0.0047µF or 4.7e-9F.
Offline amyk
That code is pretty horrible, even ignoring the fact that you can write numbers directly in 1en notation in JS it looks like someone just copy-pasted the same block and changed it multiple times. Just map into exponents (e.g. ["pF", "nF", "uF", "F" ] into [-12, -9, -6, 1]), find difference between in and out exponents for each field, and multiply by 10^n. I get the feeling whoever wrote it doesn't understand SI. :palm:
Offline jpanhalt
Just a small point...is the exponent for F a 1 or 0?  That is, 62 pF = 62 X 10E-12; 3 F = 3 x 10E0
John
Offline Brumby
It is a 0.
