Additionally on what tautech says:
- the devices that are to be used on 220/230/240 Volt mains have a typical upper limit on 265VAC, that is the plus 10% of 240VAC. The lower limit, for proper operation, is around 198V.
- the horizontal "dancing" of the signal is just one pixel. Decreasing the time base, you can see that the line is not exactly vertical, so the instrument places the signal one time to one pixel and the other to the next one...
