Hello to all:
I am trying to learn about electronics on the side. I have several of these digital volt/amp meters, and they all insist on displaying 00.0, instead of 0.00; I can't find ANY meters for sale in this format that are advertised to acutally do this
I've also read in at least one place that "if current is below 10 amps, no shunt needed"...my pics say otherwise, ummm, why?
The other two pics show a strip of LED's attached, one as-is and one with the amp reading adjusted as far as it will go (still not accurate)
Any informed comments are welcomed...I'm already resigned to probably buying/trying a different vendor's meter in the future, but I've designed and 3d-printed special housings specifically for these meters, so to get actual use out of them is still a desired goal.
