I am trying to devise a simple circuit to take the output from a Hall effect ACS712 current measuring IC module measuring into an OpAmp used as a comparator to have its output go high when more than 20 Amps is taken by the circuit. I have some LM741's and have bread boarded just the 741, a 50K multi turn pot as a resistive divider, a 12V supply and a LED with a 1k dropper resistor on the 741's output to ground. I need the comparator to output 12V when the input from the Hall effect device goes over 1.2V which is what it outputs when supplying around 20 Amps. I am ignoring the Hall effect device for now and just inputting around 1.2V to the 741 directly from a different bench supply
My issues are, the LED permanently glows, albeit dimly, although at a certain set input voltage level (from a separate bench supply) it glows brightly, and secondly it is extremely hard to set it to trip around such a low voltage accurately. I tried a 1K multi turn pot and that was seemingly no better.
I have, I think, an idea as to what's wrong, but don't have the knowledge to work out a cure. If I measure the multi turn preset resistor out of circuit, set to as near to a change over at 1.2 V input, the wiper to end of track is about 150 Ohms at one side, and over 9K at the other, on the 1K pot. So the resistive divider is needing to be skewed dramatically. The fix though?
Is the 741 not suitable for my purpose? What should I be using? I have a feeling I once heard someone say using an ordinary OpAmp as a voltage comparator is not a very good idea.
What am I doing wrong please?
Thanks for any replies.
