The filter cutoff frequency is the -3db point, so remember that at the cutoff or Fc of the filter, approx. 7 kHz, the attenuation will be 3db (-3db from the input). The attenuation continues at -6db per octave or -20db per decade as the octaves/decades go up.
so at 150kHz, your switching frequency, the attenuation will be between 27 - 30 db down from where it started. This is what you want. This is why the filter is much lower then your switching frequency. I'd even be tempted to go lower.
You can play with the LC values to get somewhere near 7khz, it's not crucial. And I'd even go lower, down to 1Khz or so, but you should use an online LC filter tool, or an offline tool like ELSIE to figure out the values. There are many pairs of LC values that the formula 1/(2*pi SQRT(L*C) ) = 7Khz (or 1Khz)
which values for L and C should you choose? the answer lies with the impedance of the source and load.
You can figure the source impedance is very low, and the load impedance will also be low, since it's a power supply. So if you use an online filter tool like this one
http://www.wa4dsy.net/filter/hp_lp_filter.html then you get the following, for a 1 kHz filter with a 1 Ohm source and load (the tool only goes down to 1 Ohm)
This is a 3rd order filter. It's a good one. It will attenuate down 60db at 150Khz. The L's are 160uH and the C can be 330uF.
If you only want to use a 2nd order filter, i.e. a single L followed by a C to ground, then choose 225uH and 220uF.
The datasheet's choice of 3uH and 180uF is probably more to do with trading off size and an acceptable 25-30db attenuation at 150kHz. More attenuation requires either moving the 3db point to a lower frequency, or choosing a higher order filter. But choosing a higher order filter just to use small parts doesnt help if you need more of them; it just takes up more board real-estate. Furthermore, depending on the real voltage level of the ripple, it may be the case that 25-30db attenuation is actually all that is needed, at which point a 7Khz 2nd order filter of 3uH and 180uF is good enough. How and where you trade off these issues is dependent on your design goals.
As for brands, well you only have to watch a few teardown videos here to know which ones are good and which are bad. Basically, everyone likes Panasonic,Rubycon, Sanyo, Nichicon, Nippon, TDK, and United Chemi-Con. There are probably others, but that's a good list.
