Author Topic: Diodes in parallel.  (Read 8771 times)
Offline chemelec
Re: Diodes in parallel.
« Reply #25 on: July 18, 2018, 03:38:53 pm »
Just a Low Value resistor Helps, Thus Not much power loss.
Offline Zero999
  • 0999
« Reply #26 on: July 18, 2018, 03:53:26 pm »
How lower value?
I believe it needs to generate a voltage drop, greater than the voltage mismatch between diodes, which might not be that much. Every wire is a resistor, so I suppose not shortening the leads and connecting the diodes right at the ends, is better than nearer the package.
Offline SG-1
« Reply #27 on: July 19, 2018, 02:28:01 am »
You may want to search Best Battery Selector as what you are building is manufactured for industrial use.
Advice is a dangerous gift, even from the wise to the wise.
Online BrianHG
« Reply #28 on: July 19, 2018, 02:52:46 am »
An all in 1 single mosfet ideal diode device supporting up to 5 amps & 9-26v:
http://www.analog.com/media/en/technical-documentation/data-sheets/4358fa.pdf
0.025 ohm on resistance, so, if you draw 1 amp, expect a voltage drop of 0.03v, not a pitiful schottky 0.4v.  That's more than an order of magnitude of improvement.
Now, for the top 2.5v-5.5v device, this one has 2 ideal mosfet diodes in 1 ic package, however, it has a 0.12v drop at 1 amp, but there is a bonus digital output indicator of which power source is currently in use & and it has an over voltage protection:
http://www.analog.com/media/en/technical-documentation/data-sheets/441312fg.pdf
Ok, for now I will stop with the ideal diodes, but, if you need it, they do have versions at different voltages and currents, and versions for use with external mosfets where you can get your voltage drop down to 0.01v, but with additional caveats.
Now, hint, there is an even better all in one diode in a TO-220 package designed for reverse bias protection or serialization of solar panels in the above 40 amp range, but, it does have a small continuous pulse switching time caveat & it's pricey, but I'll let you google that one if you need such a fancy device.
« Last Edit: July 19, 2018, 02:59:00 am by BrianHG »
