Author Topic: Eneloop AA battery short circuit current and other questions  (Read 5889 times)
Offline davTopic starter
« on: August 24, 2017, 10:43:33 am »
I tried to measure the short circuit current of an AA Eneloop battery (1,2V 1900mA, white version, BK-3MCCE).
Voltage at no load: 1,36V
Just made a brief short circuit and my meters measure:
voltage: 1,34V
current: 440mA (about)
I took a look to the discharge characteristic (datasheet downloaded here:)
http://eneloop101.com/wp-content/uploads/BK-3MCC-AE.pdf
and I have some questions:
1) is it safe to drain 440mA from the battery? (it's the short circuit current)
2) the characteristic shows a curve at 6000mA (!). Is it possible to drain more current than its short circuit current? (probably with an electronic load)
3) is it safe to drain 6000mA from this battery??
Offline cowana
Re: Eneloop AA battery short circuit current and other questions
« Reply #1 on: August 24, 2017, 10:55:52 am »
voltage: 1,34V
That's not a short circuit, which by definition has a voltage of zero.
It looks like you applied a load of around 3 ohms (1.34 / 0.44).
Offline VK5RC
« Reply #2 on: August 24, 2017, 11:12:01 am »
Doesn't it appear to have an internal resistance of about 0.2  \$\Omega\$, your test circuit and meter presumably added up to the extra resistance i.e. 2.8 ohms.
It won't last long at 6A - after 10mins it will be below 1.0V - that is from fully charged and a new battery.
Offline sibeen
« Reply #3 on: August 24, 2017, 11:18:44 am »
You have to take into account the internal resistance of the battery,
Offline sasa
  • Hobbyist in electronic
« Reply #4 on: August 24, 2017, 11:33:39 am »
You have to find the "C" value of specific battery series...
For 3th generations of Eneloop battery I have and use (last produced by Sanyo), if remember correctly, safety drain limit is  up to 1A (I would check if you want) in order to retain maximum predicted life of charge/discharge cycles. Probably similar for the 4th and 5th generations as well.
If you need more capacity and more current to drain, perhaps better choice are the "black" series (radically less charge/discharge cycles, however higher capacity and probably the "C" value).
The 30+ years professional desktop software designer and software engineer
Offline tszaboo
« Reply #5 on: August 24, 2017, 11:54:12 am »
Look at the discharge characteristics of the battery. There are several curves. One with 6A discharge curve. So is it safe? Yes, if you keep the battery in the 0°C - 50°C range.
So you need to realize, that you did not measure the short circuit current properly. Maybe the burden voltage of the meter is the issue, maybe the leads, maybe you are using it on a wrong range.
Ni-Mh batteries are much much safer than Li-Ion. Hovewer:
Ni-MH batteries feature a gas vent that allows the release of hydrogen when the battery is misused. Gas will not be released under normal usage conditions, but hyper-electric discharge or short circuit can cause internal gas pressure to rise and gas to be expelled. This gas contains hydrogen and sealed devices can’t diffuse the gas, so any source of ignition may potentially cause fire.
Offline wraper
  • Country: lv
« Reply #6 on: August 24, 2017, 12:45:37 pm »
If the battery is not dead, it's internal resistance in negligible compared to that.
« Reply #7 on: August 24, 2017, 02:33:23 pm »
Thanks to all for replies.
Battery was not dead and, during the "short", doesn't overheated.
No, I don't need to drain 6000mA.
I just would like to try some experiments (induction, electromagnet...) with coils.
On youtube a lot of guys simply direct connect an AA battery to the coil, with no resistors for limiting the current.
For safety reasons first I checked (for approx. 4-5 seconds) how many high should be the short circuit current of the battery (I used a short piece of wire and 2 meters).
Then I removed the DMM used as voltmeter and current seems to be the same (440mA).
So the question is: is it safe do direct connect the battery to a coil for some minutes?
Online IanB
« Reply #8 on: August 24, 2017, 02:43:01 pm »
Something is wrong. The short circuit current from an AA Eneloop will be well over 10 amps. The internal resistance of the cell should be from 25 to 50  milliohms, producing a peak current of around 1.2 V / 50 milliohms = 24 A. The wire you use to make the short may get red hot, and the battery will get hot too. Don't do this with a good battery.
Note: I sometimes test the short circuit current of an alkaline cell using the 10 A range on a multimeter (it will be several amps). But I won't do this with an Eneloop as it might blow the fuse.
If your battery is only giving 500 mA something is wrong. Either your battery is damaged or the resistance of your test setup is too high.
« Last Edit: August 24, 2017, 02:47:20 pm by IanB »
Online IanB
« Reply #9 on: August 24, 2017, 02:45:39 pm »
You can do this with an alkaline battery. Don't do it with an Eneloop unless the coil has a reasonable resistance (0.2 ohms or so).
Offline Audioguru
« Reply #10 on: August 24, 2017, 03:04:19 pm »
My Energizer and Duracell Ni-MH AAA (700mAh) and AA cells (2300mAh) have the same "comes pre-charged and charge lasts for one year" chemistry as Eneloop cells. When fully charged and not worn out they deliver 4A to 5A to my Fluke multimeter (0.3 ohms with leads). When an old cell cannot deliver more than 1A when shorted with my meter I call the manufacturer and have it replaced under warranty if it is less than 5 years old.
Cheap Chinese AAA Ni-MH cells (300mAh) in my solar garden lights deliver 3A to 4A when new. They do not have Eneloop chemistry and do not work anymore after about 1 year but have no warranty.
Your battery holder and electromagnet coil have resistance that limits the current so that your cell under test is not shorted.
Offline sasa
« Reply #11 on: August 24, 2017, 04:08:54 pm »
A 1900mA rated NiMH battery cells usually cannot store more energy than Ultra Power alkaline battery (Duracell or similar). I would not waste fresh Eneloop battery for similar test which obviously can damage it badly. If NiMH battery overheat, cells will be permanently damaged. If initially was shorted without testing is it overheated, probably is damaged.
I use 4xAA 1900mA Eneloop batteries for digital camera and with display on and using flash easily can be make more than 200 photos (never tested more actually, without flash once was 800), however, after 10 or 15 in a row, the container with batteries is notable hot.
« Last Edit: August 24, 2017, 04:19:54 pm by sasa »
