Author Topic: Mysterious connector (fan of the DP832)  (Read 2177 times)
Offline ElektronikLaborTopic starter
    • YouTube: ElektronikLabor
« on: March 19, 2014, 08:30:34 pm »
Hello,
I'm searching for the name of the connector for the blowers of the power supply Rigol DP832; I can't find anything :(
Below 3 pictures of the connector.
Please help me
Offline Legion
Re: Mysterious connector (fan of the DP832)
« Reply #1 on: March 19, 2014, 09:00:14 pm »
Looks like a JST PH connector. But your's has 4 wires coming off it, normally there's only two.
« Last Edit: March 19, 2014, 09:07:38 pm by Legion »
« Reply #2 on: March 19, 2014, 09:38:44 pm »
Thanks Legion,
the JST PH looks for me a little bit different; here a pic of it:
The JST PH has only one bar at one side; the connector I'm searching for has two parallel bars. Maybe it's a some sort of variation?
BTW: The connector has 2 pins; Rigol violated it with two parallel blowers (2 wires per pin)  :palm:
Offline notsob
« Reply #3 on: March 19, 2014, 10:15:01 pm »
looks like the JST XH series [2.5mm pitch] - try digikey for them
« Reply #4 on: March 19, 2014, 10:33:04 pm »
Thanks,
That looks promising!
I will buy the crimp contacts tomorow in a local store and order the housings today :)
Thumbs up for the competence of both of you, notsob and Legion!  :-+
