Author Topic: Discrete linear audio power amplifier schematic KENWOOD KA-7300  (Read 3453 times)
Offline strawberryTopic starter
  • Country: lv
Is this good amplifier schematic?
« Last Edit: July 24, 2017, 01:49:53 pm by strawberry »
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
Re: Discrete linear amplifier schematic
« Reply #1 on: May 20, 2017, 09:26:00 pm »
its a classic design from 1990s or earlier, served well until it died and was replaced by an UcD amp.
We Are The Watt - Resistance Is Futile!
Offline BrianHG
    • LinkedIn
« Reply #2 on: May 20, 2017, 10:49:48 pm »
What are your objectives?
The amp schematic you provided should work fine.
Do you want something just to copy?
How much power do you need?
What are your skills in making such a circuit?  A +/- 60v, or 120v total supply can do some damage and possible harm if you are not careful.
Do you have just a volt meter, or, do you have access to a scope?
What kind of sound quality are you expecting?
This amp still has an op-amp IC in it, so, it's not really considered all discrete.
  • Country: lv
« Reply #3 on: July 24, 2017, 01:47:56 pm »
To replace/repair KENWOOD KA-7200 power amplifier
supply rails +/-50V
Is it necessary to equalize currents between both differential amplifiers?
