Electronics => Beginners => Topic started by: strawberry on May 20, 2017, 07:22:42 pm
Title: Discrete linear audio power amplifier schematic KENWOOD KA-7300
Post by: strawberry on May 20, 2017, 07:22:42 pm
Is this good amplifier schematic?
Title: Re: Discrete linear amplifier schematic
Post by: tatus1969 on May 20, 2017, 09:26:00 pm
its a classic design from 1990s or earlier, served well until it died and was replaced by an UcD amp.
Post by: BrianHG on May 20, 2017, 10:49:48 pm
What are your objectives?
The amp schematic you provided should work fine.
Do you want something just to copy?
How much power do you need?
What are your skills in making such a circuit?  A +/- 60v, or 120v total supply can do some damage and possible harm if you are not careful.
Do you have just a volt meter, or, do you have access to a scope?
What kind of sound quality are you expecting?
This amp still has an op-amp IC in it, so, it's not really considered all discrete.
Post by: strawberry on July 24, 2017, 01:47:56 pm
To replace/repair KENWOOD KA-7200 power amplifier
supply rails +/-50V
Is it necessary to equalize currents between both differential amplifiers?
