Author Topic: Discrete Regulated power supply  (Read 14908 times)
Offline blackdog
  • Please stop pushing bullshit...
Re: Discrete Regulated power supply
« Reply #50 on: July 13, 2018, 07:23:33 am »
Hi Cliff Matthews,
I am currently busy with the work and administration involved.
Some measurements have already been made and of course it generates.  :-DD
But not at a frequency you would expect.
The power supply is easy to set up and to load with 1 or 2 Ampere, so that works.
But debugging takes a lot of time, and I don't have that available now, probably next week.
A bit of patience please  :)
Kind regards,
Bram
Necessity is not an established fact, but an interpretation.
The following users thanked this post: Cliff Matthews
Offline schmitt trigger
  • Country: mx
« Reply #51 on: July 13, 2018, 01:29:31 pm »
Blackdog;
I really like your prototype assembly techniques. They show you took the time to lay out things properly.
I specially like your "copper clad chassis". Very ingenious! And it makes a good ground plane too.
Offline GigaJoe
« Reply #52 on: July 14, 2018, 05:34:12 pm »
So what the goal ? mediocrity PSU on 2 transistors ?  I may sound sarcastic , but really it not 80x  when find some opamp like to find a precious gemstone
for a zener need const curr, and diff amp need  const curr as well - to minimize pulsation
Offline blackdog
« Reply #53 on: July 14, 2018, 06:06:41 pm »
Hi GigaJoe,  :)
I have already explained in this topic that with two opamps you can make a much better power supply.
But also that I like to work occasionally with discrete's, just for fun.
And not to forget, I am still learning from it!
I've already placed some extra "stopping" resistors here and there to avoid oscillations.
At a certain load and output voltage, oscillation occurs around 45 MHz!  :-DD
Touching the collector who is grounded from the differential amplifier, changed the frequency and level, total length of this wire 1.5cm!
Welcome in the world of small fast modern transistors...
A good reason to not do it this way  :)
Some pictures
Testing with a Heatkit dummy load.
The red circels are ground wires, all change the oscillation frequency.
Blue circle, wextra power decoupling off the board, can be removed again.
Small pink circle, collector is now connected via en small 100 Ohm resistor to ground.
Later more.
Kind regards,
Bram
Offline GigaJoe
« Reply #54 on: July 14, 2018, 07:12:50 pm »
OK, got it, even pay attention on circuit, that i missed ...
does osculation happens when current limiter involved ?  That usually a problem with all compensating VR, current pushing regulated signal down, when in the same time a second half trying to compensate it ... that when oscillation happens.
so need to change signal on input of diff ampl.
Offline GigaJoe
« Reply #55 on: July 14, 2018, 07:50:23 pm »
silly ideas:  dif amp - darlington,   output from a zener going to another zener - that would be a vref;
Offline mike_mike
« Reply #56 on: March 06, 2019, 06:42:14 pm »
Hello,
Is there any way to add more than 2 power transistors in the attached schematic ?
I don't need more output current, just more power transistors in parallel. It is enough to add more transistors with emitter resistors in parallel or I need to make other modification ?
The maximum output current set by P3 will be 5A and maximum output voltage set by P4 will be 27-28V.
Offline not1xor1
« Reply #57 on: March 07, 2019, 06:02:36 am »
Hello,
yes, you can  :D
that PSU is already so bad that there is no chance you can make it worse  >:D
Offline Cliff Matthews
    • General Repair and Support
« Reply #58 on: March 07, 2019, 12:50:01 pm »
@not1xor1 - If he adds one or 2 more, shouldn't he at least upgrade the PNP driver to a TIP42c or similar?? (Ic = 6a)
Offline IanMacdonald
    • IWR Consultancy
« Reply #59 on: March 07, 2019, 06:33:40 pm »
Yes, I would advise a TIP42C as a more substantial driver. You could also look at using 2N3773's instead of the 2N3055s. They are not much more expensive and are quite a bit higher rated.  Especially in voltage. (Which matters more than it might seem because the current handling of a transistor drops off quite rapidly as you approach its voltage rating - known as secondary breakdown.)
Other useful mod is that you can make P1 and P2 'bad wiper safe' by adding a high value resistor from the wiper to the minimum volts/current end. Say 220k. This will ensure that the supply goes to min output instead of max if the wiper goes open circuit.
Offline not1xor1
« Reply #60 on: March 08, 2019, 06:14:50 am »
so the current required by the PNP driver would be approximately the same
the same because the maximum output current doesn't change, is just split among more BJTs
approximately because hFE vs. IC is not flat
