Hi GigaJoe,
I have already explained in this topic that with two opamps you can make a much better power supply.
But also that I like to work occasionally with discrete's, just for fun.
And not to forget, I am still learning from it!
I've already placed some extra "stopping" resistors here and there to avoid oscillations.
At a certain load and output voltage, oscillation occurs around 45 MHz!
Touching the collector who is grounded from the differential amplifier, changed the frequency and level, total length of this wire 1.5cm!
Welcome in the world of small fast modern transistors...
A good reason to not do it this way
Some pictures
Testing with a Heatkit dummy load.
The red circels are ground wires, all change the oscillation frequency.
Blue circle, wextra power decoupling off the board, can be removed again.
Small pink circle, collector is now connected via en small 100 Ohm resistor to ground.
Later more.
Kind regards,
Bram
