Electronics => Beginners => Topic started by: dds on September 04, 2013, 08:38:53 am
Is it possible to buy somewhere display like this one ?
I suppose you can custom order some... but you'd need minimum orders of thousands, maybe.
Digikey has such custom lcd screens from time to time, but in low number... i guess overstock made for some company... and they're hard to find.
There are dot matrix lcd displays with i2c or sci interface (128x128 , 128x32 , x64 etc) which are easy enough to use and you can create custom icons on screen for what you need, but generally they're a bit more expensive because of the driver on the back side ...3-5$ maybe if you buy 100 pcs... for example : http://www.digikey.com/product-detail/en/COG-C144MVGI-08/153-1146-ND/2523706 (http://www.digikey.com/product-detail/en/COG-C144MVGI-08/153-1146-ND/2523706)
Thereis at least one standard one. It was made for the icl7134 i believe. That is or was an autoranging dmm ic.
i hope this can work for few things.
http://www.ebay.com/itm/1pcs-6-bit-segment-LCD-Display-Module-Digital-Seg-LCD-/140918780524 (http://www.ebay.com/itm/1pcs-6-bit-segment-LCD-Display-Module-Digital-Seg-LCD-/140918780524)
Here you go:
http://www.soselectronic.cz/a_info/resource/l/trumeter/APM.pdf (http://www.soselectronic.cz/a_info/resource/l/trumeter/APM.pdf)
You can search for them by their model number.
if it's one off, you can buy a dirt cheap DT830 and just use its LCD...
Fluke-29-ll-or-79-ll-NOS-Multimeter-LCD-Glass-Display-Panel-Series-2-ll-/370890447287?ssPageName=ADME:B:FSEL:US:1123
http://www.ebay.com/itm/Fluke-83-83-lll-85-85-lll-New-LCD-Glass-Display-Panel-83-3-85-3-/370890432445?ssPageName=ADME:B:FSEL:US:1123 (http://www.ebay.com/itm/Fluke-83-83-lll-85-85-lll-New-LCD-Glass-Display-Panel-83-3-85-3-/370890432445?ssPageName=ADME:B:FSEL:US:1123)
http://www.ebay.com/itm/Fluke-21-3-23-3-75-3-77-3-New-Multimeter-LCD-Glass-Display-Panel-Series-3-lll-/331012611528?ssPageName=ADME:B:FSEL:US:1123 (http://www.ebay.com/itm/Fluke-21-3-23-3-75-3-77-3-New-Multimeter-LCD-Glass-Display-Panel-Series-3-lll-/331012611528?ssPageName=ADME:B:FSEL:US:1123)
I have a strong feeling I know where that seller got those displays. Via another seller on ebay. The other seller sold the displays in packs of 8 and 10. Let's just say he likely paid about half the price of one for the lot of 8 or 10. Every now and then this other seller gets a new batch which always seems to end when I have a meeting at work. |O
