Author Topic: Power Supply Running to hot  (Read 7578 times)
Offline JblissTopic starter
Re: Power Supply Running to hot
« Reply #25 on: July 13, 2015, 04:32:05 am »
Hey if i was to try this would I use standard rectification diodes or zener or would both work because they both give a voltage drop. Of course properly rated
Offline rs20
« Reply #26 on: July 13, 2015, 04:56:20 am »
All of the above will work, even Schottky diodes will be OK. Of course you have to calculate based on the forward drops of your chosen diodes; a 0.7V silicon diode will dissipate 0.7W at 1A (nice and warm but fine), but a 5V zener will dissipate 5W at 1A (smoke).
« Reply #27 on: July 13, 2015, 05:02:53 am »
could i use some 1n4004
Offline rs20
« Reply #28 on: July 13, 2015, 06:00:44 am »
What's the supply current? Try doing the calculation yourself, and we'll check for you.
