Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
MOSFET driving
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: MOSFET driving (Read 1954 times)
yashrk
Frequent Contributor
Country:
A MAKER, AN ENGINEER, A HOBBYIST FOR LIFE
MOSFET driving
on:
July 13, 2015, 01:21:27 pm »
Hey guys
I was just seeing multiple videos on MOSFET switching and many of them where emphasising on keeping stable ground connection and keep the switching part (N- channel with driver or P- channel) on the high side. Non of them where clear about why they prefer the high side switching over the low side switching.
In what type of situations or circuits should I be concern about low side switching ??
Logged
Find me and things I'm working on -
https://www.yashkudale.com/
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
Re: MOSFET driving
Reply #1 on:
July 13, 2015, 01:50:21 pm »
Low side switching is easier as everything is referenced to ground but it means that you disconnect your loads ground which is not always possible. High side switching gets around this but the gate voltage is then referenced to the positive supply so it's hard when say you have a 12V circuit with a 3.3V control to control a gate that is at 12V when off and 9V when on. Level transitioning is required.
Logged
yashrk
Country:
Re: MOSFET driving
Reply #2 on:
July 13, 2015, 02:00:02 pm »
Ohk so if its possible to switch the load using ground (which in my case is possible as its just a battery charger circuit) then I should go for it and it doesn’t have any other problem right ?
And if there is need of N- channel in high side what kind of ICs or bootstrap circuit do you prefer (battery is of 12V hence the gate voltage won't go too high)
Logged
Simon
Global Moderator
Country:
Re: MOSFET driving
Reply #3 on:
July 13, 2015, 02:05:33 pm »
You can use N or P channel for highside, P is easier but N channel mosfets are cheaper for big ones and have better specs so if it is a lot of power it makes sense to have the bootstrap circuit and the N channel on a highside.
Logged
yashrk
Country:
Re: MOSFET driving
Reply #4 on:
July 13, 2015, 02:14:01 pm »
Thank you for the reply but just want to know what types of bootstrap circuit do you prefer or which ICs (easily available) are used ?
Logged
PSR B1257
Country:
Re: MOSFET driving
Reply #5 on:
July 13, 2015, 03:07:46 pm »
Depends of how you want to switch the MOSFET.
For PWM (duty cycle from 0.1 to 0.9 or there about and not too low frequencies) operation a
usual
bootstrap circuit will work.
For static switching (i.e. DC=1 or low switching frequencies) you need an auxilary pule generator, which is charging the boot strap capacitor.
You can build up such a circuit with a NE555 or use an IC like
http://www.intersil.com/content/dam/Intersil/documents/isl6/isl6801.pdf
Logged
In theory, there is no difference between theory and practice. But, in practice, there is.
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
MOSFET driving
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
