yes, extrapolating it, at 60MHz its about -50dB 2nd harmonics, thats very negligible (should be invisible) compared to what i got. 3rd harmonic is wobbly but maybe at -40dB? thats still very little. fig 48 shows undistorted 1% vs Vpp, that may explains it but still not really obvious, maybe later i need calculate THD of signal that i got, but from visual, its very unacceptable and THD should be several magnitude higher than -40dB. are you saying this is normal? the 200MHz BW only for small signal? attached is another output signal how bad it is... cheers.
