Author Topic: diy 2.5v voltage source  (Read 1722 times)
Offline METopic starter
« on: March 08, 2025, 03:41:48 am »
Is it possible to  get a stable 2.5v for the control voltage for an ocxo using a tl431?.
Offline Smokey
  • Not An Expert
Re: diy 2.5v voltage source
« Reply #1 on: March 08, 2025, 04:09:16 am »
Offline Andy Chee
« Reply #2 on: March 08, 2025, 04:27:55 am »
Yes, you can generate a stable 2.5V using a TL431.
Be aware, the TL431 is a shunt regulator.  This differs from the LM317 and 7805, 78xx regulators which are series regulators.
The following users thanked this post: ME
« Reply #3 on: March 08, 2025, 07:36:06 am »
Can anyone give me a rough drawing of a schematic to do it?.
Online RoGeorge
« Reply #4 on: March 08, 2025, 07:59:40 am »
Take the 'Simplified Schematic' on the first page from the datasheet linked by Smokey.
If you apply +5V at 'Input', the resistor should be 220\$\Omega\$ for best performance (to get roughly 10mA through TL431).
VKA will be 2.5V, your reference voltage.
The following users thanked this post: Smokey, ME
Offline Gyro
« Reply #5 on: March 08, 2025, 10:40:14 am »
If it's for a precise application like an OCXO Vadj, you probably want something more temperature stable than a TL431. There are many 2.5V low Tc Bandgap references available, eg, LT1009, REF03 etc.
Best Regards, Chris
« Reply #6 on: March 08, 2025, 02:47:57 pm »
its because i have some 431 components to hand,i dont want to order yet,thier was a fella built a freq ref with them using a cti 10Mhz ocxo, I cant find the thread tho.
Offline TimFox
« Reply #7 on: March 08, 2025, 05:08:23 pm »
The TI data sheet (and the sheets for the other precision units cited) specify the stability and temperature performance of the devices.
Offline floobydust
« Reply #8 on: March 08, 2025, 06:03:08 pm »
The LT1009 is a 2.5V shunt regulator, it comes with these low cost 10MHz OCXO boards.
You could put in a TL431 with no problem, aside from the value of capacitor C6 across it. Some makes of TL431 will oscillate depending on that value, so I would first check their datasheet i.e. pg. 18 fig. 6-18 . There's only 3 pins to worry about. TL431 datasheet. Same pinout in TO-92.
I'm not sure how much of an effect ref 100ppm/°C vs 15ppm/°C will have when the module control voltage spec is +/-2 ppm from 0-4V.
Quick napkin sketch 10°C change of a TL431 is 2.5mV shift, for 0.0025ppm or 0.025Hz but I might be wrong.
« Reply #9 on: March 08, 2025, 09:34:41 pm »
any chance of posting a napkin scketch on how to wire it up so i get 2.5v out,ie a rough schematic??.
Offline TimFox
« Reply #10 on: March 08, 2025, 09:38:36 pm »
For a TL431, connecting Ref and “cathode” (positive terminal) directly together forms a 2.5 V Zener diode.
Other voltages > 2.5 V require extra resistors.
All this is in the data sheet, better than a napkin.
Offline floobydust
« Reply #11 on: March 08, 2025, 09:44:54 pm »
Same circuit as you or 807 posted in the other thread.
TL431 Anode to GND, K or Cathode is +2.5V (has R4 3k3 resistor to +5V), jumper REF to K.
Offline Andy Chee
« Reply #12 on: March 09, 2025, 03:56:28 am »
Rough schematic is available on page 26
https://www.ti.com/lit/ds/symlink/tl431.pdf
Offline Picuino
    • Picuino website
« Reply #13 on: March 09, 2025, 10:26:30 am »
Add a potentiometer for fine regulation.
Offline Picuino
    • Picuino website
« Last Edit: March 09, 2025, 11:15:55 am by Picuino »
Offline Refrigerator
  • Country: lt
« Reply #15 on: March 09, 2025, 06:06:56 pm »
Connecting the reference pin to the cathode of the TL431 and adding a shunt resistor will make the simplest voltage reference.
But if you want more current you can add a single NPN transistor and now you will have what is basically a 2.5V voltage regulator.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline Konkedout
« Reply #16 on: March 09, 2025, 07:03:39 pm »
I think the pass transistor is a good idea, but I would be a bit worried about oscillation.  I have added some additional parts to help prevent that but my values are "guesstimates".  You may need to experiment on the bench.  I do not completely trust simulation to guarantee stability.  Different versions of the TL431 are different!  Please see my schematic image.
For Q1; 2N3904 is OK for lower current up to 50-100 mA.  2N4401 works well if the current is higher.  There is a lot of overlap between these two transistor types.
R1=1K is good for 8V-12V input; you may need to lower it for lower V_INPUT.
R2, R3, and C1 are feedback loop compensation.
R4 and C2 are some output bypass.  The TI TL431 datasheet describes using resistance in series with output capacitors to insure stability.  Adding Q1 makes instability more likely so my warning of possible instability ought not be ignored.
R5 is a minimum load. If your actual load current can ever get down below 1-2 mA you may need this.  R5 = 1K may be better but that will burn more power.
Offline floobydust
« Reply #17 on: March 09, 2025, 08:22:54 pm »
The load requirement for the VCOCXO control voltage pin is very low about 10uA. So I don't see a need for the NPN buffer transistor, the TL431 etc. circuit alone has enough current available.
Also, I haven't confirmed if the control voltage pin sources any current, which is something else to consider but a dummy load resistor looks after this in the added buffer transistor circuit posted.
« Reply #18 on: March 09, 2025, 08:59:24 pm »
I want this to provide vref for a OSC5A2B02 module before it gets trimmed with a multiturn preset pot.
