Long time Youtube viewer. First time trying to fix a slightly more than basic device: an audio effects processor. Please be gentle.
At first it seemed like it was "just a blown fuse" but when I replaced it, as soon as I plugged it in, the fuse blew again, so it is some short somewhere.
I started by checking all the diodes with my crappy 2$ multimeter and right off the bat I got different kinds of readings, which got me confused about:
1) which diodes are good and which are not and
2) what type of diodes they are.
I didn't take out the board so I don't know what is going on on the other side of the board, but just to mention the diodes that are easily accessible:
- D1 through D4 show a reading of 710 in both directions.
- D6 through D8 show a reading of 750 in the flow direction and OL on Reverse.
- D9 shows a reading of 70 in both direction.
- ZD1 shows 75 on both directions
- ZD2 and ZD3 show 950 in the flow direction and OL on Reverse.
In terms of their working state, by looking at these readings it looks like almost all diodes are faulty, which is a little hard to believe. Is this true or am I missing something/getting bad results because of in-circuit readings?
When it comes to diode identification the question is more generic: how can I tell if a Diode is a rectifier, zener or just regular? Searching on the internet it seems that this can only be done by looking at their datasheets, but some of these diodes seem to be only marked with two digit numbers (like 48, 27, A2) which I was assuming was their voltage rating until I saw the A2 one and which makes it very difficult for the noob me to even find the datasheet. In this particular case, the Z in ZD1-ZD3 seems to indicate they are Zener diodes but that's pretty much all I've got.
Here are some pictures:
