Author Topic: LDO (TC1071) misbehaving  (Read 4394 times)
Offline bryce1Topic starter
« on: May 29, 2015, 10:58:02 am »
I cant for the life of me get the voltage I want out of the TC1071. I am sure I misunderstand something in the datasheet.
The voltage divider in my case is 750k(R1) / 470k(R2), which should result in 3.1V?
Instead, I see 4.1V.
What is happening???
http://ww1.microchip.com/downloads/en/DeviceDoc/21353E.pdf
PS: I am using 1uF ceramics on the input and output. The ouput cap has a 0.5 resistor in series to account for the low esr.
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
Re: LDO (TC1071) misbehaving
« Reply #1 on: May 29, 2015, 12:05:32 pm »
I take it its as drawn on page one of PDF. have you actually mounted it on a PCB or bodged it onto a strip board?
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
« Reply #2 on: May 29, 2015, 12:16:34 pm »
I have it on a pcb
Offline mikerj
« Reply #3 on: May 29, 2015, 12:51:02 pm »
What are you using for the output decoupling cap?  Does it meet the ESR requirements of this LDO?
Offline tron9000
« Reply #4 on: May 29, 2015, 02:34:45 pm »
says its ceramic but From reading the datasheet it doesn't specify not using a ceramic cap, but does say an alu electro or tant can be used. Just for clarity have you tried it without your 0R5 resistor mod in?
Offline Odysseus
« Reply #5 on: May 29, 2015, 03:00:59 pm »
Verify that the ADJ pin is ~1.2V.  You can also try shorting ADJ to the output and see if that gives you 1.2V.  Your cap and resistor should be sufficient. What is Vin and your load?
« Last Edit: May 29, 2015, 03:11:04 pm by Odysseus »
Offline PSR B1257
« Reply #6 on: May 29, 2015, 03:14:17 pm »
750k(R1) / 470k(R2)
Nominal value or actually measured?
What type of resistor?
A picture of your PCB might help  ;)
In theory, there is no difference between theory and practice. But, in practice, there is.
Online wraper
  • Country: lv
« Reply #7 on: May 29, 2015, 04:03:43 pm »
Where you bought it? Check if the marking matches the datasheet - BBNN
« Reply #8 on: June 01, 2015, 01:20:27 am »
I bought it on digikey, it is the right part.
Vin is about 4.6V. Load varies, not more than 10mA.
750k(R1) / 470k(R2)
Measured. I tried different 0603 resistors and one through hole.
Offline PSR B1257
« Reply #9 on: June 01, 2015, 02:57:56 pm »
Just for curiosity, have you verified your measurement with a different meter?
Perhaps you have damaged the chip due to excess heat during soldering. Do you have a spare chip?
« Reply #10 on: June 02, 2015, 02:57:56 am »
I tried three different ones.
Offline PSR B1257
« Reply #11 on: June 02, 2015, 04:17:41 am »
Meters or chips?
Offline tron9000
« Reply #12 on: June 02, 2015, 08:23:14 am »
If we had some photies of the PCB, then this would help, might be able to spot something?
« Reply #13 on: June 06, 2015, 05:51:41 am »
You where right to insist on this, the problem lies elsewhere in the circuit. When I test the LDO config in an isolated manner, everything works just fine.
Offline matkar
  • Country: si
  • Sixty percent of the time it works EVERY time.
« Reply #14 on: June 06, 2015, 09:39:52 am »
How much current does the circuit draw? If it doesn't go over specs try to increase regulator's output capacitor. I bet you use a 0603 1uF low voltage ceramic  one. Use at least 10uF ceramic or better yet replace it with a tantal. And remove the 0R5 resistor. Next time stick to the datasheet recomendations.
