Author Topic: 1 Hz Low Pass Filter  (Read 3967 times)
Offline fourierpwnTopic starter
« on: August 24, 2017, 06:43:18 am »
Hi all,
A typical measurement setup used to measure 1/f noise is to use a 1 Hz low pass filter in order to filter out any noise that is present on the DC bias voltages from a given SMU and obtain "clean" DC.
All attempts at building a simple RC filter have not yielded results that seem correct. This filter is not specific to the type of measurements it is being used for, so essentially I am just after a ? 1Hz LPF to clean up some DC voltages. Sounds simple enough (probably is, I'm just too noob) but I would appreciate as far as practical designs.
Offline Benta
Re: 1 Hz Low Pass Filter
« Reply #1 on: August 24, 2017, 07:39:15 am »
At frequencies that low, component values get so large that it's practically unmanageable and you get into all sorts of leakage and other parasitic problems.
If at all possible, I'd recommend an active filter, but even there you'll have to watch out for parasitics.
Offline bson
« Reply #2 on: August 24, 2017, 04:01:45 pm »
Use an active filter for such low frequencies!
Offline eliocor
    • rhodiatoce
« Reply #3 on: August 24, 2017, 04:25:54 pm »
« Last Edit: August 25, 2017, 04:19:20 am by eliocor »
Offline Benta
« Reply #4 on: August 24, 2017, 06:52:09 pm »
If you read the OP, the goal is to measure 1/f noise. I'd expect any kind of switched filter to counteract that goal. Just sayin'
Online jpanhalt
« Reply #5 on: August 24, 2017, 08:40:47 pm »
How about lead-acid batteries?  We ran our Beckman DU spectrometers from them.
