Author Topic: Faulty schematic.  (Read 2778 times)
Offline bastouwTopic starter
Faulty schematic.
« on: February 28, 2014, 04:30:16 pm »
Hello, I am reading the The Art Of Electronics 2e Edition.
The topic VOLTAGE REGULATORS AND POWER CIRCUITS have examples of bad cirquits.
And 2 of them i have troubble reasoning whet the fault is.
Can someone help me?  Here are the attached schematics:
Offline grumpydoc
Re: Faulty schematic.
« Reply #1 on: February 28, 2014, 04:40:21 pm »
I'm wondering how the first one starts given that the op amp power supply is taken after the pass element.
Not sure about the second for a moment....
Ah, yes - once the current limit transistor has turned on it will feed lots of base current to the pass transistor, probably not what was intended.
I think those are the faults - anyone agree (or disagree for that matter).
« Last Edit: February 28, 2014, 04:43:24 pm by grumpydoc »
Offline Andy Watson
« Reply #2 on: February 28, 2014, 05:14:53 pm »
Agreed. The first pass transistor in the first circuit will require driving with a base voltage 0.6-0.7 above the supply rail to the op-amp. It's not going to happen, even with a rail-to-rail op-amp!
