Author Topic: Simple Sweep Generator  (Read 3538 times)
Telequipment
  • Guest
« on: June 26, 2013, 02:36:44 pm »
Hi everyone,  I have a need for a sweep generator , but would like to build my own if possible one up to 5/10 Mhz, do any of you have any idea's please.
Paul
Offline Paul Price
Re: Simple Sweep Generator
« Reply #1 on: June 26, 2013, 03:22:31 pm »
Paul,
What kind of output...sinewave I assume
Telequipment
  • Guest
« Reply #2 on: June 26, 2013, 03:34:21 pm »
Hi Yes if possible, I have a function generator and one of the inputs states "sweep input", so I wonder if that means sweep generator input or I wonder if it means a Sweep oscillator input, then use the function generators  range, either way I don't mind , I'm just at a loss how to go about building one.
Paul
Offline WBB
« Reply #3 on: June 26, 2013, 05:38:11 pm »
My guess is it's a VCF (Voltage Controlled Frequency) input. The voltage presented to that input determines the frequency. You would feed a ramp signal into that input and the frequency will follow the voltage of the ramp signal.
Telequipment
  • Guest
« Reply #4 on: June 26, 2013, 06:41:06 pm »
Yes I've done it, function generator on sine wave 20 kHz then I fed a 6 kHz from my signal generator into the sweep input of the generator, and its sweeping brilliant . Thanks WBB for making me use the grey matter
