Author Topic: Power arduino from 12 volts?  (Read 3825 times)
Offline EEVPiobeeTopic starter
« on: February 07, 2014, 08:39:33 am »
Hello there!
What is the best way to power an arduino chip (ATtiny, ATmega etc.) from a 12 volt (regulated) source? Is this the Classic LM7805 voltage regulator or is there a more efficent way to do so? (less loss of power thru heat dissipation)
Thank you!
Offline VK5RC
Re: Power arduino from 12 volts?
« Reply #1 on: February 07, 2014, 09:28:36 am »
I have used one of the small switch mode dc-dc converters (one with not too much ripple) with success. Got it from MiniKits in Sth Australia,  regards Rob
Offline PICmonster
« Reply #2 on: February 07, 2014, 10:06:55 am »
Using a linear reg is the cheapest and most traditional way and has less noise at the expense of power dissipation :D, a switcher is more efficient so runs cooler but has more noise as mentioned, this noise could be a significant proble when using ADC, generally the higher the ADC resolution the more power supply noise becomes a problem.
« Reply #3 on: February 07, 2014, 11:00:32 am »
Thank you for the hints!
Now mentionning the ripple, I guess I'm gonna go for the voltage regulator since I haven't thought of that problem (deh!) ...
Maybe on some other project I'll go with a dcdc when I'll need the arduino not to fail on any voltage circumstance (with proper filtering of course!)
But... It makes me wonder... If I use a DC-DC to step down from whatever voltage input (let's say 24 for this example) down to 7.5 ( keeping some headroom) and -then- put in a LM7805 to clear the 5 volts would it help? or am I looking only for headaches and trouble?...
(Actually, I'm considering the user dumb enough to eventually use the wrong power supply with the module I'm building)
Offline sleemanj
  • Professional tightwad.
« Reply #4 on: February 07, 2014, 11:08:47 am »
Yes that's a common configuration.
Of course, you still need appropriate filtering caps on the 7805 (which you need anyway even if you don't use a DC-DC).
Offline VK5RC
« Reply #5 on: February 07, 2014, 12:00:19 pm »
Bizarrely, I got quite a bit of confidence using some of these dc-dc switchers after using one inside a 3W RF out 10GHz microwave transverter. I was expecting the harmonics to drive everything into overload but it went OK. I have since found several dc-dc converters inside commercial kits for amateur radio microwave transverters (they still have to meet stringent spurious radiation limits, typically harmonics less than 80dB).
These in-the-field Ham microwave transverters are a DC power supply nightmare, often 13.8V in, and you need -7, +5,9,12,24V in a single unit!
I used an Arduino (with its display shield- I know I am lazy) as a relatively quick way of displaying several bits of useful information at the same time e.g. Supply Voltage and Current draw. You can put in an over-voltage/current shut down routine in the code and help maintain the 'magic smoke' inside! Out in the field it is really easy to mis-connect something (or not) and puff, the smoke is out, HiHi.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: February 07, 2014, 12:54:10 pm »
Odd, I'd be quite surprised if a GHz system noticed a switching converter: there are rarely harmonics beyond 100 or 200MHz (or perhaps more for monolithic converters).  If it's a poorly designed system of course (i.e., poor band limiting in any stages), it could be susceptible to lots of sources.
Some exceptions include poorly made chips.  There's a National chip somewhere that runs its synchronous buck output stage such that the GND side body diode is driven as a step-recovery diode, resulting in a quite reasonable sub-ns blip.
What's the source, how much does power consumption matter?  I take it, it's not battery operated?  How much do you need at 5V?  Just a few mA for the MCU alone, or are there other things attached (say, an LCD with backlight that gobbles a few hundred mA)?
Plug-in hardware, with stuff like the latter, I would be fine with a 7805.  An LCD backlight is kind of a pain, but a little heatsink on the 7805 and that's plenty.  If this is battery powered, you'll probably want to maximize life, meaning using low-power modes in the MCU whenever possible (cuts current consumption from ~10mA flat out, down to perhaps uA if it doesn't need to do much), and a micro/nanopower SMPS chip to furnish the 5V (roughly doubling battery life versus a low-quiescent LDO).
Seven Transistor Labs, LLC
