A battery should be effectively noiseless. A switching regulator won't be.
Quote from: tggzzz on April 15, 2025, 10:25:03 amA battery should be effectively noiseless. A switching regulator won't be. Perhaps you aren't aware of recent product development, which is a 3.7 lithium battery and 1.5V buck converter, all packaged inside an AA sized cylinder.https://www.amazon.com.au/Lithium-Rechargeable-Battery-2600mWh-Constant/dp/B0C3H1JH4F?th=1https://www.cocoonpower.com/product-page/ebl-usb-rechargeable-aa-batteries-3300mwh-quick-charge-4-packIn this context, the so-called "battery" as a complete AA assembly is noisy, rather than noiseless. No doubt the internal 3.7 lithium battery itself would be noiseless.Unfortunately I can't comment on the actual noise performance, as I've never used these batteries before, let alone measured their switching noise.
Standard NiMH chemistry rechargeable batteries will give you none of the noise that a LiPo/Li-ion battery with a buck/boost circuit on the end of it would. Or it might be possible in many situations to use a LiPo/Li-Ion 3.7V cell directly.
