I have been looking at some delta sigma ADC IC's, I need a 24bit delta sigma to get the average voltage of a signal that changes faster than the output rate of the delta sigma. Most delta sigmas have output rates of 100's of samples per second.
My question is: If my signal is a 10kHz sine wave, and I use a 24bit delta sigma that outputs 100 samples per second, will the delta sigma average the 10kHz sine wave so that in the output I will have the real average of the wave even when I'm only getting 100 samples per second?
Thanks!
