Author Topic: Do dual mosfets max VDS doubled, in the back to back connection as a switch ?  (Read 1042 times)
Offline BravoVTopic starter
  • +++ ATH1
With identical mosfets, does the maximum VDS doubled at the switched line ?
For e.g. each max breakdown VDS = 100V, with this configuration will it become 200V ?
Assuming the gate driver is fully isolated, like using photovoltaic MOSFET driver.
« Last Edit: December 19, 2018, 07:02:19 am by BravoV »
Offline capt bullshot
No, it does not.
One of the MOSFETs is reverse biased in this configuration, so its internal diode is conducting and pushing all the voltage drop to the other one.
The following users thanked this post: BravoV
  • +++ ATH1
No, it does not.
Ah, thanks, forgot the body diodes at both fets.  :palm:
So the max breakdown simply = (A single VDS) + (Single body diode VF) ?
Back to drawing board to find suitable MOSFETs.
Or even simpler just the single VDS, since the body diode VF usually is significantly lower than the breakdown voltage, especially as long as it isn't carrying current.
  • +++ ATH1
Yeah, noted, as the VF is minuscule compared to VDS, again, thanks.
