Author Topic: Modifying / Adding a Frequency Counter to a Vintage Signal Generator  (Read 1213 times)
Offline GlassmanTopic starter
I would like to add a frequency counter to my old Trio SG 402 Signal Generator similar to whats been done in this video and hopefully make it a bit more accurate as I'd like to eventually align some old Transistor Radios & CB radio's etc
I have SDR radio on my lap top and it picks up the tone coming from the Sig Gen so I know it works and that the analogue adjustment is slightly out, also
- For some reason my SDR doesn't go below 10mhz and need to know I'm generating a tone at 455khz
- I have found that the Frequency Counter fluctuates / doesn't lock
- The difference between the analogue display and frequency counter increases the further down in     frequency I go.
- I then tried using an RF amp set up similar to whats been done in this next video and the counter seem to stabalise and lock around 25mhz - 30mhz with the Sig Gen set to High and full RF gain.
Am I wasting my time trying to attempt this?
Should I look at a better frequency counter than the one I got off AliExpress? Is there an SDR that goes down to 455khz? Is the RF amp a bit of gimmick?
Admittedly I didn't do the greatest job putting everything together i.e. long wires & no coax used, just wanted to see if the amp would make a difference which it did but not as good as what I hoped for.
Trio manual, schematic and external & internal photos & RF amp
https://mega.nz/folder/ZxEWRDYR#SHJYkWr2b_1hyvyD5Bth2Q
Thanks for taking the time to view this
Offline David Hess
  • DavidH
Re: Modifying / Adding a Frequency Counter to a Vintage Signal Generator
« Reply #1 on: October 31, 2022, 02:00:19 am »
It makes perfect sense to do that.  Two of my signal generators work exactly like that.
The frequency counter probably has an AC coupled input causing its sensitivity to decrease at low frequencies.
The following users thanked this post: Glassman
« Reply #2 on: October 31, 2022, 03:08:05 am »
Thanks for you reply David.
Did you modify the signal generators yourself and if so what sort of Frequency Counters did you use?
Offline David Hess
  • DavidH
« Reply #3 on: October 31, 2022, 04:25:27 pm »
These had the frequency counter built in, but worked in the way you describe.  They were not synthesized, so the generator was completely analog with a separate digital frequency counter.
I am sure the problems you are having are because the frequency counter from AliExpress is not suited to what you are trying to do, but I do not have any better suggestions.  Some units are better than others.
On my other analog function generators, I use an external frequency counter as needed.  What you might do is add a frequency generator output to your signal generator which is constant amplitude to drive an external general purpose frequency generator.
